-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Foam::error::printStack (https://www.cfd-online.com/Forums/openfoam-solving/133643-foam-error-printstack.html)
1988 April 18, 2014 02:23
hi Formers
I am using IcoFoam solver and I didn't have any problem but as soon as scaling the geometry to millimeter I have got this error during processing.
Time = 0.006
Courant Number mean: 4.75321e+76 max: 3.75818e+81
DILUPBiCG:  Solving for Ux, Initial residual = 0.999964, Final residual = 1.021, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.999977, Final residual = 1.08934, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.999987, Final residual = 1.05489, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 2.87353, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 4.77489e-26, Final residual = 4.77489e-26, No Iterations 0
time step continuity errors : sum local = 7.20173e+114, global = 3.05681e+97, cumulative = 3.05681e+97
DICPCG:  Solving for p, Initial residual = 2.08226e-25, Final residual = 2.08226e-25, No Iterations 0
time step continuity errors : sum local = 3.14056e+115, global = -4.27954e+98, cumulative = -3.97386e+98
ExecutionTime = 869.68 s  ClockTime = 874 s
Time = 0.007
Courant Number mean: 3.30783e+115 max: 3.16723e+119
[0] #0  [1] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at ??:?
[0] #1  Foam::sigFpe::sigHandler(int) at ??:?
[1] #1  Foam::sigFpe::sigHandler(int) at ??:?
[0] #2  Uninterpreted:
[0] #3  at ??:?
[1] #2  Uninterpreted:
[1] #3  in "/usr/lib/libmpi.so.0"
[0] #4  in "/usr/lib/libmpi.so.0"
[1] #4  in  in "/usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so"
[1] #5  "/usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so"
[0] #5  in "/usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so"
[1] #6  PMPI_Allreduce in "/usr/lib/openmpi/lib/openmpi/mca_coll_tuned.so"
[0] #6  PMPI_Allreduce in "/usr/lib/libmpi.so.0"
[1] #7  void Foam::allReduce<double, Foam::sumOp<double> >(double&, int, ompi_datatype_t*, ompi_op_t*, Foam::sumOp<double> const&, int) in "/usr/lib/libmpi.so.0"
[0] #7  void Foam::allReduce<double, Foam::sumOp<double> >(double&, int, ompi_datatype_t*, ompi_op_t*, Foam::sumOp<double> const&, int) at ??:?
[1] #8  Foam::reduce(double&, Foam::sumOp<double> const&, int) at ??:?
[0] #8  Foam::reduce(double&, Foam::sumOp<double> const&, int) at ??:?
[1] #9  at ??:?
[0] #9  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constFoam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #10  at ??:?
[1] #10
[0]  at ??:?
[0] #11  [1]  at ??:?
[1] #11
[0]  at ??:?
[0] #12  [1]  at ??:?
[1] #12
[0]  at ??:?
[0] #13  [1]  at ??:?
[1] #13
[0]  at ??:?
[0] #14  [1]  at ??:?
[1] #14
[0]  at ??:?
[0] #15  __libc_start_main[1]  at ??:?
[1] #15  __libc_start_main in "/lib/i386-linux- in gnu/libc.so.6"
[0] #16  "/lib/i386-linux-gnu/libc.so.6"
[1] #16
[1]  at ??:?
I have read this link but I could not find the solution
HTML Code:
http://www.cfd-online.com/Forums/openfoam-solving/95674-high-courant-number-icofoam.html
this is checkMesh
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            885385
    internal faces:  864251
    cells:            291606
    faces per cell:  6
    boundary patches: 3
    point zones:      0
    face zones:      0
    cell zones:      0
Overall number of cells of each type:
    hexahedra:    291606
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:    0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch              Faces    Points  Surface topology
    body                19650    19700    ok (non-closed singly connected)
    inlet              742      768      ok (non-closed singly connected)
    outlet              742      768      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.0142294 0 -0.0151572) (0.0129588 0.0472016 0.0022)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (3.0901e-17 -9.27854e-17 -1.34611e-16) OK.
    Max cell openness = 3.32518e-16 OK.
    Max aspect ratio = 9.66007 OK.
    Minimum face area = 8.65714e-10. Maximum face area = 8.93054e-08.  Face area magnitudes OK.
    Min volume = 2.58464e-13. Max volume = 1.87293e-11.  Total volume = 1.09182e-06.  Cell volumes OK.
    Mesh non-orthogonality Max: 24.5048 average: 5.06496
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.361877 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
and this is the controldict file:
application    icoFoam;
startFrom      startTime;
startTime      0;
stopAt          endTime;
endTime      4.8;
deltaT          0.001;
writeControl    timeStep;
writeInterval  20;
purgeWrite      0;
writeFormat    ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision  6;
runTimeModifiable true;
libs (
    "libOpenFOAM.so"
    "libgroovyBC.so"
fvSchemes(completely the same as fvscheme which had been defined in cavity folder)
ddtSchemes
    default        Euler;
gradSchemes
    default        Gauss linear;
    grad(p)        Gauss linear;
divSchemes
    default        none;
    div(phi,U)      Gauss linear;
laplacianSchemes
    default        none;
    laplacian(nu,U) Gauss linear orthogonal;
    laplacian((1|A(U)),p) Gauss linear orthogonal;
interpolationSchemes
    default        linear;
    interpolate(HbyA) linear;
snGradSchemes
    default        orthogonal;
fluxRequired
    default        no;
    p              ;
this is fvSolution again the same as cavity example \
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance      1e-06;
        relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance      1e-05;
        relTol          0;
PISO
    nCorrectors    2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue      0;
is there anyone who can give the solution?
adambarfi April 18, 2014 02:36
your solution can't be converged because of your very high Courant Number,
Time = 0.007
the Courant number is:
CoNum = 0.5*gMax(sumPhi/mesh.V().field())*runTime.deltaTValue()
so,I think that your boundary conditions aren't match with your geometry dimensions. calculate your non-dimensional numbers and check where is the problem.
If they are reaonable for your problem, decrease the deltaT.
1988 April 18, 2014 05:36
there is no way to change the boundary conditions because the simulation become completely wrong so I cant do anything about boundaries meanwhile about time steps I have to mention that they are set to 0.001 second and the end time is 4.8 so reducing the quantity of time step would be so costly .there is no other way?
