-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Floating point exception (core dumped) in transonicMRFDyMFoam (https://www.cfd-online.com/Forums/openfoam-solving/134378-floating-point-exception-core-dumped-transonicmrfdymfoam.html)
sam.ho April 29, 2014 01:30
3 Attachment(s)
Dear Foamers:)
I am simulating a radial inflow turbine bassage with cyclic BC on periodic surfaces and overlapGgi at interface between Upstream and impeller and impeller and downstream.
BC and initial values are attached. Rotational speed is 2303.1833 RPS.
I am using transonicMRFDyMFoam.
When I run the case I am getting the following error.
What could be the Problem.
Please guide me.
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/run/Turbine_CASE_25.04.2014$ transonicMRFDyMFoam
| \\      /  F ield        | OpenFOAM Extend Project: Open source CFD        |
|  \\    /  O peration    | Version:  1.6-ext                              |
|  \\  /    A nd          | Web:      www.extend-project.de                |
|    \\/    M anipulation  |                                                |
Build  : 1.6-ext
Exec  : transonicMRFDyMFoam
Date  : Apr 29 2014
Time  : 10:48:49
Host  : BMH301562
PID    : 17621
Case  : /home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_CASE_25.04.2014
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh staticFvMesh
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Allocating field rho
Reading field U
Creating MRF model
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
    Prt            0.9;
    alphaK1        0.85034;
    alphaK2        1;
    alphaOmega1    0.5;
    alphaOmega2    0.85616;
    gamma1          0.5532;
    gamma2          0.4403;
    beta1          0.075;
    beta2          0.0828;
    betaStar        0.09;
    a1              0.31;
    c1              10;
Create Riemann solver
Allocating field rhoU
Allocating field rhoE
Allocating physDeltaT list for RK and Dual-Time Stepping
Starting time loop
 Time = 0.001
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
rho L2 Residual: 5.19706734243579
rho LInf Residual: 6.20573608985886
DILUPBiCG:  Solving for omega, Initial residual = 0.00246886183755971, Final residual = 3.63820329446736e-09, No Iterations 1
bounding omega, min: -10676725.9096259 max: 81480676744.9903 average: 143370435.93326
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 2.09741132236342e-10, No Iterations 3
bounding k, min: 0 max: 8675.38724898184 average: 8659.50215296127
    ExecutionTime = 22.74 s
 performance data:
  Head (m)  = 5.67916442932999e+301
  TOmega (W) = 53.4715203093837
  Eff (%)    = -9.59774223073677
  Forces    = (0.0997502247768037 -0.207201815211534 1.00882792747902)
  Moments    = (-0.00637111953414955 -0.0145051677747836 -0.00369499754906964)
 Fluid power output:
  dEm (W) = -557.126030517272
forces output:
    forces(pressure, viscous)((0.0224118219595117 -0.0123873558684275 0.0493579078322118) (0.0773384028172919 -0.194814459343106 0.959470019646804))
    moment(pressure, viscous)((-0.00643573254076094 0.000227855362752766 -0.000200221603628329) (6.46130066113849e-05 -0.0147330231375363 -0.00349477594544131))
 Time = 0.002
bounding rho, min: -7.23432991465607 max: 87.0577875756529 average: 0.0697171344957788
bounding rhoE, min: -4199206.588189 max: 51019869.3767982 average: 30668.4900360114
bounding U max: 379103.25524316
bounding h, min: -566302.774909988 max: 361487480.588983 average: 571891.979824179
rho L2 Residual: 5.2129917782982
rho LInf Residual: 6.18558520131841
