Floating point exception (core dumped) in transonicMRFDyMFoam |
April 29, 2014, 01:30 |
Rep Power: 12 |
Dear Foamers
I am simulating a radial inflow turbine bassage with cyclic BC on periodic surfaces and overlapGgi at interface between Upstream and impeller and impeller and downstream. BC and initial values are attached. Rotational speed is 2303.1833 RPS. I am using transonicMRFDyMFoam. When I run the case I am getting the following error. What could be the Problem. Please guide me. Code:
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/run/Turbine_CASE_25.04.2014$ transonicMRFDyMFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext Exec : transonicMRFDyMFoam Date : Apr 29 2014 Time : 10:48:49 Host : BMH301562 PID : 17621 Case : /home/sml5kor/OpenFOAM/sml5kor-1.6-ext/run/Turbine_CASE_25.04.2014 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh staticFvMesh Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Allocating field rho Reading field U Reading/calculating face flux field phi Creating MRF model Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { Prt 0.9; alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; c1 10; } Create Riemann solver Allocating field rhoU Allocating field rhoE Allocating physDeltaT list for RK and Dual-Time Stepping Starting time loop Time = 0.001 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 rho L2 Residual: 5.19706734243579 rho LInf Residual: 6.20573608985886 DILUPBiCG: Solving for omega, Initial residual = 0.00246886183755971, Final residual = 3.63820329446736e-09, No Iterations 1 bounding omega, min: -10676725.9096259 max: 81480676744.9903 average: 143370435.93326 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 2.09741132236342e-10, No Iterations 3 bounding k, min: 0 max: 8675.38724898184 average: 8659.50215296127 ExecutionTime = 22.74 s performance data: Head (m) = 5.67916442932999e+301 TOmega (W) = 53.4715203093837 Eff (%) = -9.59774223073677 Forces = (0.0997502247768037 -0.207201815211534 1.00882792747902) Moments = (-0.00637111953414955 -0.0145051677747836 -0.00369499754906964) Fluid power output: dEm (W) = -557.126030517272 Head (m) = 5.67916442932999e+301 forces output: forces(pressure, viscous)((0.0224118219595117 -0.0123873558684275 0.0493579078322118) (0.0773384028172919 -0.194814459343106 0.959470019646804)) moment(pressure, viscous)((-0.00643573254076094 0.000227855362752766 -0.000200221603628329) (6.46130066113849e-05 -0.0147330231375363 -0.00349477594544131)) Time = 0.002 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 bounding rho, min: -7.23432991465607 max: 87.0577875756529 average: 0.0697171344957788 bounding rhoE, min: -4199206.588189 max: 51019869.3767982 average: 30668.4900360114 bounding U max: 379103.25524316 bounding h, min: -566302.774909988 max: 361487480.588983 average: 571891.979824179 rho L2 Residual: 5.2129917782982 rho LInf Residual: 6.18558520131841 Floating point exception (core dumped) |
floating point exception | oldirtybrindley | OpenFOAM Running, Solving & CFD | 2 | March 8, 2014 16:56 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 10:21 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
