May 6, 2014, 04:43 |
Wrong velocity profile in pipe
Fredo
Rep Power: 11 |
Hello Foamers,
I am a beginner with OpenFoam and I am stuck with a problem here. I am trying to run non Newtonian flow in a pipe and I have got strange results ; I did a 5 degree piece of a pipe with wedge condition. I know the mesh seems bad but I don't think that it is the problem here. My probleme is the following ; For the first iterations, I have a velocity profile with 0 on the axis and on the wall (fig U_it100_5degree_pipe). Resulting a low shear rate at half radius (fig shearRate_it100_5degree_pipe) and so very high viscosity values (fig nonNewtonian_it100) since a power law is used. The more the computation runs, the more this high viscosity region goes to the axis and get stabilized (fig nonNewtonian_it60000). I need a lot of iterations to converged (60000). I did the same for a full pipe (fig mesh_full_pipe) and 2000 iterations where enough to converged and I didn't have a zero velocity at the axis for the first iterations. My question is ; The profile I get for the first iterations, is it due to ; - a bad mesh ? I have tried several and in the end the probleme is still here but can be lowered. - periodic condition ? I used wedge, cyclic and cyclicAMI and it didn't change my problem. As I have a one mesh case in y direction, in the end it's normal it doesn't change anything, right ? - the "empty" condition on the axis that could induce a 0 velocity for the first iterations ? Many thanks for your help, Fredo. link to figures and input files : https://www.dropbox.com/sh/i4nyfyp3jgimktv/hTsgJTkypM |
pipe, profile, velocity |
Display Modes | |
3D UDF Paraboilc Velocity Profile (Can't Maintain) | Sing | FLUENT | 12 | August 7, 2017 06:25 |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 12:14 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
particle velocity and velocity profile | HGG | FLUENT | 2 | June 10, 2001 16:32 |
