foam-extend-3.0: GAMG & mixingPlane
Hello everyone,
for my centrifugal compressor passage model setup I'm trying to implement a combination of a GAMG solver and a rotor stator interface of the type mixingPlane.
According to the foam-extend-3.0 release notes, GAMG should be working in conjunction with a mixingPlane interface. Therefore, it's strange that following error message appears:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Not implemented
[0]
[0] From function mixingPlaneGAMGInterface::agglomerateCoeffs
[0] in file matrices/lduMatrix/solvers/GAMG/interfaces/mixingPlaneGAMGInterface/mixingPlaneGAMGInterface.C at line 81.
[0]
FOAM parallel run aborting
[0]
Does it mean that it's really not implemented or did I simply forget to set a flag somewhere? The entry for p in my fvSolution file is as follows:
p
solver GAMG;
tolerance 1e-08;
relTol 0.05;
smoother DIC;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 20;
agglomerator faceAreaPair;
mergeLevels 1;
Maybe, someone has an idea. Thanks a lot :)
