Species become stagnant in reactingFoam
Old   May 11, 2014, 10:42
Default Species become stagnant in reactingFoam
IN
rohitpurdue is on a distinguished road
Hello Everyone,
I am trying to simulate premixed flame using one-step global reaction mechanism and PaSR model. I am now running only the non-reacting case, after running the simulation for sometime I found that in the log file number of iterations for specie CH4 is equal to zero and when I plot them I see that CH4 has stopped moving and becomes stagnant with time. This is how the log file looks.
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 4.81997e-05, Final residual = 1.17875e-07, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 4.54775e-05, Final residual = 1.00746e-07, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 6.17566e-06, Final residual = 1.03197e-08, No Iterations 1
DILUPBiCG:  Solving for O2, Initial residual = 2.59847e-06, Final residual = 8.45414e-09, No Iterations 1
DILUPBiCG:  Solving for H2O, Initial residual = 8.70219e-07, Final residual = 8.70219e-07, No Iterations 0
DILUPBiCG:  Solving for CH4, Initial residual = 5.39512e-07, Final residual = 5.39512e-07, No Iterations 0
DILUPBiCG:  Solving for CO2, Initial residual = 8.70219e-07, Final residual = 8.70219e-07, No Iterations 0
DILUPBiCG:  Solving for h, Initial residual = 7.62988e-07, Final residual = 7.62988e-07, No Iterations 0
min/max(T) = 292.129, 1597.65
DICPCG:  Solving for p, Initial residual = 0.00147716, Final residual = 7.77343e-05, No Iterations 1
time step continuity errors : sum local = 1.61415e-06, global = 2.16576e-07, cumulative = 0.0100902
DICPCG:  Solving for p, Initial residual = 7.77416e-05, Final residual = 9.1615e-07, No Iterations 19
time step continuity errors : sum local = 1.61366e-06, global = 2.13379e-07, cumulative = 0.0100904
bounding k, min: 2.23952e-38 max: 1.0119 average: 0.00109675
ExecutionTime = 14190 s  ClockTime = 14266 s
Courant Number mean: 6.74676e-05 max: 0.499129
deltaT = 7.19424e-06
Time = 0.145194
The species equations are being solved and everything looks fine except above problem, can anyone suggest anything.
Thanks a lot in advance,
Rohit
rohitpurdue is offline   Reply With Quote
Old   May 12, 2014, 00:50
Bobby
babakflame is on a distinguished road
Greetings Rohit
Lower the tolerance of your solvers in fvSolution file. (Especially Yi)
I think then you will have your CH4 Matrix solved.
Regards
Bobi
babakflame is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
