May 16, 2014, 14:22 |
Drag Coefficient in flow over a cylinder
Rep Power: 12 |
Hi everybody,
I know this problem has been posted by many people but i just can't find an answer for it. I am trying to simulate a laminar flow over a cylinder using simpleFoam. (re=300) but i have trouble with Cd and Cl , their magnitudes are not close to the magnitudes in articles and papers. I use the following code to get Cd and Cl : forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 1; patches ( cylinder ); pName p; UName U; rhoName rhoInf; log true; CofR (0 0 0); rhoInf 1; } forceCoeffs { type forceCoeffs; functionObjectLibs ( "cylinder.so" ); outputControl timeStep; outputInterval 1; patches ( cylinder ); pName p; UName U; rhoName rhoInf; log true; liftDir (0 1 0); dragDir (1 0 0); CofR (0 0 0); pitchAxis (0 0 1); magUInf 1.00; rhoInf 1; lRef 1; Aref 1.4; } I'm not sure what Aref and LRef should be ? are they the diameter of the cylinder ? I read somewhere that Aref is diameter*domain length in the z direction ? Any help would be appreciated ! |
May 16, 2014, 17:03 |
1. Aref is the front area of the cylinder, Lref is diameter of cylinder. 2. Usually mistake is in CofR, it should be the center of cylinder. 3. If you are trying to compare with published values, make sure you've got more-or-less the same mesh. As it appears values of Cd (especially) and Cl depend on mesh density. Once I've made a comparison of influence of different parameters on simulation results - http://matveichev.blogspot.fr/2014/0...ex-street.html |
May 16, 2014, 22:00 |
Rep Power: 12 |
Thanka for your reply
Does the front area mean diameter*domain in the z direction? I dont really get it, bcuz it's a 2d simulation. |
May 17, 2014, 03:01 |
I've used diameter*(size of domain in Z-direction), results were quite similar to the published ones.
May 17, 2014, 08:33 |
Rep Power: 12 |
Thanks alexeym, how do you determine the size of domain in Z direction?
May 17, 2014, 08:55 |
If you created mesh with blockMesh, the answer is obvious, look in blockMeshDict. Also you can run checkMesh, it will show sizes of the mesh.
May 17, 2014, 09:52 |
Rep Power: 12 |
No , i have created the mesh using Gambit and then transfered it to a Foam mesh . because it is a 2d mesh , i can't view the 3rd dimension in Gambit
May 17, 2014, 10:05 |
But when you import the mesh into OpenFOAM you should have a mesh with third dimension.
May 17, 2014, 10:12 |
#9 |
Rep Power: 12 |
I am starting to think that there might be sth wrong with the solution ,
my case is a laminar one so in RAS properties i changed the RAS model to laminar , should i do sth else or is this the only thing i have to do ? and for changing the amount of nu, is it enough to just change it's magnitude in the nut and nutilda files or should i change them in some place else ? |
May 17, 2014, 11:44 |
#10 |
Kinematic viscosity of the fluid is set in constant/transportProperties file.
May 18, 2014, 09:23 |
#11 |
Rep Power: 12 |
the results seem to be good for Re=40 , but for Re=300 and 1000 , Cd is 1.1 but it should be around 1.5
Any thoughts what the problem might be ? |
May 18, 2014, 09:59 |
#12 |
1. Mesh can affect Cd greatly.
2. Are you sure solution converges on every time step? |
May 18, 2014, 12:49 |
#13 |
Rep Power: 12 |
thanks again ! I have simulated the same case and mesh with fluent and the results are fine .
But i can't get the same results with openFoam . do you know what Reynolds number is considered turbulent for vortex shedding ? I have used laminar solver in fluent for all the 3 reynolds number : 40 , 300 , 1000 and the results are close to published results. But in openFoam i only got a good results for re=40 , using laminar solver? Should i use a turbulent solver for Re=300 and 1000 ? |
May 18, 2014, 13:02 |
#14 |
Post your case files, tell the meaning of "results are fine". As I'm not sure that your case is set up correctly, I can't suggest you anything.
May 19, 2014, 11:21 |
#15 |
Rep Power: 12 |
My problem is solved now , I was using SimpleFoam for an unsteady solution ! such a stupid mistake ! I used icoFoam instead and now everything is fine !
Anyways , I want to thanks you for your time and effort to help me get through this, I really appereciate your help ! |
Flow past rotating cylinder: Problem with ForeCoeffs | raf1111 | OpenFOAM | 1 | December 16, 2013 09:45 |
Flow past cylinder (Re=10^5) | lbeaudet | Main CFD Forum | 9 | June 2, 2009 03:59 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Drag and Lift in 3D flow around a cylinder... | Renato N. Elias | Main CFD Forum | 16 | October 4, 2005 11:32 |
drag and lift coefficient of compressible cylinder | Bin Li | Main CFD Forum | 1 | March 7, 2004 09:49 |
