[swak4Foam] minimum value
Old   May 27, 2014, 04:24
Default minimum value
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I need to get the minimum and maximum pressure value in my domain for each time step. I tryed
prMin
        type swakExpression;
        valueType cellZone;
        zoneName FLUID;
        accumulations (
            average
        expression "min(p)";
        verbose true;
prMax
        valueType cellZone;
        zoneName FLUID;
        accumulations (
            average
        expression "max(p)";
        verbose true;
in my controlDict but I am not sure, if that is the correct way. I get slightly different values in paraFoam, but I am not sure if that is just some interpolation problem.
Can someone confirm the code or tell me how to do it right?
Philipp.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   May 28, 2014, 03:55
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I do not think you need to use swak (unless you need additional functionality I am not aware of). The standard functionobject should work as well:
minMax
         // Type of functionObject
         type            fieldMinMax;
          // Where to load it from (if not already in solver)
         functionObjectLibs ("libfieldFunctionObjects.so");
          // Function object enabled flag
         enabled         true;
          // Log to output (default: false)
         log             false;
          // Write information to file (default: true)
         write           true;
          // Fields to be monitored - runTime modifiable
         fields
             p
Regards,
Tom
Last edited by tomf; May 28, 2014 at 03:57. Reason: Improving indentation in code part
tomf is offline   Reply With Quote
Old   May 28, 2014, 03:56
Philipp
Great, I am going to try that! Thanks
Edit: Alright, I'm getting the same values. Thank you again!
Old   May 28, 2014, 12:22
Assistant Moderator
Bernhard Gschaider
Originally Posted by RodriguezFatz View Post
prMin
        valueType cellZone;
        zoneName FLUID;
        accumulations (
            average
        verbose true;
prMax
        valueType cellZone;
        zoneName FLUID;
        accumulations (
            average
        verbose true;
Philipp.
Just do
prMin
        valueType cellZone;
        zoneName FLUID;
        accumulations (
            min
            weightedAverage
            max
        expression "p";
        verbose true;
(weightedAverage is an added bonus)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Skewness , Minimum Edge Length and Mesh Quality in FLuent ViLaks FLUENT 2 March 2, 2017 05:57
Minimum PDF enthalpy exceeded during injection, without physical explanation Daveo643 FLUENT 1 November 2, 2015 11:47
Get the maximum and minimum pressure in the domain(In parallel calculation) xh110120 Fluent UDF and Scheme Programming 4 October 10, 2014 08:06
AMI: Minimum patch weight decreases with time lordvon OpenFOAM Running, Solving & CFD 2 September 3, 2013 12:39
Setting a minimum temperature value WillemvdM OpenFOAM Running, Solving & CFD 0 February 3, 2010 02:37
