interFoam channel hull parasitic currents?
Like Tree1Likes
  • 1 Post By wyldckat
Old   May 27, 2014, 05:43
Default interFoam channel hull parasitic currents?
Mirco Brunke
Mock is on a distinguished road
Hi Foamers,
this is my first post and i'm not sure if it is at the right place... and not so good in writing englisch... But my problem is:
I use interFoam with OpenFoam 2.3. The case is a wind tunnel with two phases and a geometrie inside. Boundary conditions and all other settings are like the tutorial DTCHull in interDyMFoam but without moving mesh. There are only some changes at the velocity. It starts with 0 m/s and then speed up with 0.3m/s² for the whole area.
The result shows, everywhere where the grid split into smaller cells are non-physical velocities near the surface in the air phase. The picture shows a sitution like this. This is the result after 0.1 seconds. So the velocity should be 0.03m/s.
Is here anybody who knows what I did wrong or are these parasitic currents? Is there a trick to handle this problem?
I changed a little bit the interFoam solver after seeing these results. But only at the pEqn.H like some people wrote here in the Forum for parasitic currents (Brackbill or Raeini). But I didn't test the complete code of Raeini. This changing had no effect.
Greetings,
Mock
Mock is offline   Reply With Quote
Old   June 8, 2014, 09:27
Retired Super Moderator
Bruno Santos
Greetings Mock and welcome to the forum!
It looks to me that the mesh transition is in a very bad place. Have a look into this blog post of mine, so that you can get a better idea on how important the mesh is, specially "Case two": OpenFOAM: Interesting cases of bad meshes and bad initial conditions
Best regards,
Bruno
Mock likes this.
Old   August 9, 2014, 22:23
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, do you see these spikes at interphases?
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   August 11, 2014, 03:15
Mirco Brunke
Hi santiagomarquezd,
these spikes are at the air-phase. Maybe a these pictures show it better:
The red oval shows the location from the upper part of the picture (xz-plane).
Best regards,
Mock
Old   August 14, 2014, 18:26
As Bruno said, probably mesh problems.
Regards.
Research Scientist
interfoam hull
Channel flow using InterFOAM DanM OpenFOAM Running, Solving & CFD 49 July 31, 2020 11:43
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
parasitic currents rcastilla OpenFOAM Programming & Development 135 November 29, 2017 10:53
interFoam grid refinement results and parasitic currents giack OpenFOAM Running, Solving & CFD 0 June 29, 2013 12:45
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
