SurfaceElevation problem with dynamic mesh.
Hi, I have a problem with the surfaceElevation functionObject of the waves2Foam library. It doesn't work with dynamic mesh, for example with the waveDyMFoam solver. The error is:
--> FOAM FATAL ERROR: Unknown function type surfaceElevation I've tried a lot of things but none work, could someone help me please? Thank you! Michele |
Hi Michele,
did you solve that problem? I just stumbled over it myself and could not figure out a solution yet. Thanks, Pascal. -- |
Hi, no sorry I didn't solve the problem..good luck!
Hi Michele,
I was to quick with asking, and the solution is in fact rather simple (haha, once you know, it is easy to say ;-)). Just in case you are still interested: One needs to insert the library to be used in the controlDict: Code:
... controlDict stuff... Cheers, Pascal. -- |
