Home > Forums > OpenFOAM Running, Solving & CFD
non-zero velocity can not be set to blockage wall of cyclicACMI?
Old   June 11, 2014, 02:50
Unhappy non-zero velocity can not be set to blockage wall of cyclicACMI?
kkk
kenyoh
kkk is on a distinguished road
Hi Foamer!
I am trying to do tutorial of cyclicACMI with OF2.3.x oscillatingInletACMI2D.
I can not set non-zero velocity on ACMI2_blockage.
fixedValue (0 0 0) is default setting. I want to set fixedValue (10 0 0) on the ACMI2_blockage of U.
But it didn't work well. it became fixedValue (0 0 0) as time progresses.
Somebody know how to fix it?
Regard,
kkk
File Type: zip U.zip (578 Bytes, 1 views)
kkk is offline   Reply With Quote
Old   December 18, 2014, 04:08
Default cyclicACMI bug
bizkit37 is on a distinguished road
I encountered the same problem as you regarding cyclicACMIs and imposed non-zero velocities. Did you find a fix yet? I saw on the openfoam bug tracker that apparently the problem is not resolved yet. I would be very thankful for any help...
bizkit37 is offline   Reply With Quote
Old   January 20, 2015, 01:46
Default Not yet
kkk
kenyoh
Hi
I checked openfoam bug tracker after a long interval. It seems to take more time to fix it. I tried to read the scripts about cyclicACMI, I don't think I can fix it by myself. Actually,there is no choice but to wait.
Old   March 21, 2016, 22:41
Default I could find to fixed this problem
kkk
kenyoh
Hi
I found the other way to set non-zero velocity on blockage wall of cyclicACMI.
timeVaryingUniformFixedValue has to be used instead of fixedValue.
Actually,timeVaryingUniformFixedValue seemed to become obsolete in OF2.3.x.
But you can use it of OF1.7.1.
I attached "oscillatingInletACMI2D" being set timeVaryingUniformFixedValue on ACMI2_blockage of U.
I am very happy if this could help someone.
Plese don't forget wmake libso timeVaryingUniformFixedValue before running.
Regards,
kkk
Thread Tools
Trackbacks are On
Radiation interface hinca CFX 15 January 26, 2014 18:11
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 3 June 12, 2013 02:12
BC set at fixedValue (0 0 0), but I get a non-zero velocity @ wall squadron OpenFOAM Running, Solving & CFD 8 October 10, 2012 11:36
Set the velocity by using discrete data with time tseo FLUENT 0 March 4, 2008 19:16
how to print the results from CFX-4.2 cfd_99 Main CFD Forum 5 June 21, 1999 09:23
