Running snappyHexMesh with interDyMFoam
Old   June 23, 2014, 11:18
Default Running snappyHexMesh with interDyMFoam
lguillem is on a distinguished road
Hi everybody,
I am trying to run snappyHexMesh with interDyMFoam, but it seems I have a probleme.
I explain what I am doing : I took the floatingObject tutorials. I want to replace the floatingObject by an other geometry using a stl file and snappyHexMesh.
Finally, I have no problem with the snappyHexMesh (it runs well), but I have a probleme with interDyMFoam. The errors are the following errors :
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
at sigaction.c:?
#3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) at ??:?
#4 at MULES.C:?
#5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) at ??:?
at ??:?
#7 __libc_start_main at ??:?
at ??:?
Someone could help me to solve this ?
Thanks in advance.
Kind regards,
Louise
lguillem is offline   Reply With Quote
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! dancoz87 ANSYS 17 November 14, 2016 01:10
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running sunliming OpenFOAM Bugs 21 November 22, 2013 03:38
Segmentation fault running waveDyMFoam solver (mod. interDyMFoam solver - waves2Foam) Ed R OpenFOAM Running, Solving & CFD 5 July 2, 2013 11:36
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 08:08
