Natural ventilation in a room with windows
1 Attachment(s)
Hi everybody,
I am looking for the best solution (solver and BC) to simulate the natural ventilation of a room. I would like to take into consideration a room with opening surface on the outdoor, so an indoor temperature and an outdoor temperature at t=0. In addition, I would also simulate an internal load like the radiation of a human body (in W/m2 ?). (you can see the enclosed figure) The wished result could be the evolution of the temperature fields and speed fields into the room. Can anyone have already coded this kind of case ?? Maybe you can send me please JJ Don’t hesitate if you have any questions, Thanks a lot, Matthieu |
Dear Matthieu,
you can try out the: buoyantBoussinesqSimpleFoam Solver. Should be enough for you case. Bye Thomas |
Dear Thomas
thanks for your answer but do you know what kind of boundary conditions for the opening on outdoor (windows of the room) ? Inlet / outlet ? Pressure ? ... thanks a lot in advance, regards, Mat |
1 Attachment(s)
I am not sure about your window situation. Do you want open it a Little bit so the aiflow can come in or only set a surface temperature? Regards, Thomas |
in fact, I would like to consider a fully open window so, yes the airflow can come from outdoor to indoor.
In addition, I would like to take into account the radiation of an human body in the room for example (radiation in W/m2 ?). Do you understand my wish ? Have you ever seen this case ?? Thanks for your help. Mat |
Dear Mat,
I upload one case. Maybe you can start from this case and adjust it by yourself... It used buoyantBoussinesqSimpleFoam with k-Omega SST and radiations https://copy.com/YukaGKRnnBds7kSY Bye Thomas |
Hi Thomas,
thanks for your help I don't manage to run your case with buoyantBoussinesqSimplefoam ... because I am not used to working with snappyhexmesh, I use Salome. Can you explain me please ? Thanks again, Regards, Mat |
snappy is just the mesher, you may prepare your mesh in any software.
What you need is to run your buoyantBoussinesqSimplefoam on your geometry. Have a look at the tutorial coming with the case. Just be aware that the solver is using Boussinesq approximation to buoyant forces. What will be the tricky part are the open windows. Unless you want to prescribe the pressure gradient between doors and window, you need the BC on window to take into account the pressure difference across the window. It would need some testing for a suitable BC settings. Maybe even use the buoyant solver without the Boussinesq approx. calculating the real density difference. good luck matej |
in fact, I don't manage to run this case, I have several error. Do you manage to run this case on your computer ? Regards, Mat |
Dear all,
I used OpenFOAM 2.2x. Let me check the case again.... What kind of error? Bye Thomas [EDIT] I upload the case again: https://copy.com/4HXgDQjMNCPkJHl9 |
Dear all,
I copy your files on my computer, I run buoyantBoussinesqSimpleFoam and I have this error : --> FOAM FATAL IO ERROR: keyword Cp is undefined in dictionary "/home/etu/OpenFOAM/etu-2.0.0/run/TestRoom_brut/0/T::boundaryField::body_People_body_10" file: /home/etu/OpenFOAM/etu2.0.0/run/TestRoom_brut/0/T::boundaryField::body_People_body_10 from line 66 to line 70. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting Thanks for your help :):) Mat |
Do you know this error ?
Thanks, Mat |
yes: "keyword Cp is undefined in dictionary ". So add the "cp" value in "transportProperties" under "constant"-Folder like: Cp Cp [0 0 0 0 0 0 0] 1000; Bye Thomas |
Hi Thomas,
thanks for your answer. And this error, you know ? (sorry, i'm a newby ...) ******************************************** Create mesh for time = 0 Reading g Reading thermophysical properties Reading field T Reading field p_rgh Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Creating turbulence model Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; c1 10; } Reading field kappat Calculating field g.h SIMPLE: convergence criteria field p_rgh tolerance 0.01 field U tolerance 0.001 field T tolerance 0.001 field k tolerance 0.001 field omega tolerance 0.001 Starting time loop Time = 1 --> FOAM FATAL IO ERROR: Unknown convection scheme bounded Valid convection schemes are : 1 ( Gauss ) file: /home/etu/OpenFOAM/etu-2.0.0/run/TestRoom-A/system/fvSchemes::divSchemes::div(phi,U) at line 32. From function convectionScheme<Type>::New(const fvMesh&, const surfaceScalarField&, Istream&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude/convectionScheme.C at line 97. FOAM exiting ********************************** |
yes, because you used OpenFOA 2.0. Delete all "bounded" words in "fvScheme". Bye Thomas |
Hi the best thing to fight all these errors is:
a) look into tutorial case in $FOAM_TUTORIALS/heatTransfer/<solvername>/<tutorialCase> for the settings and check your settings against it. b) is there any reason why you are using 2.0 instead of the latest version 2.3? Where might be some improvements in the solver? matej |
I use VirtualBox (ubuntu), is there any solution to upgrade easily to OF 2.3 on a virtualbox ? Thanks, Mat |
Yes, the easiest way is to follow this: http://www.openfoam.org/download/ubuntu.php from your VirtualBox ubuntu window. VirtualBox is just virtual computer, so you have ubuntu runing there just as it would be installed on your computer.
looking here: http://www.openfoam.org/download/history.php there has not been much development in solver itself, but in the BC you may find usefull for your case, like thermal baffles (2 different types), mixed thermal condition. mat |
I have a lot of difficulties with my OF ....
Now : ************************************************** ********** Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0791183, No Iterations 161 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0792435, No Iterations 42 DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 0.0979706, No Iterations 9 --> FOAM FATAL ERROR: lookup of (1|A(U)) from objectRegistry region0 successful but it is not a volScalarField, it is a surfaceScalarField From function objectRegistry::lookupObject<Type>(const word&) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 114. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #4 Foam::fixedFluxPressureFvPatchScalarField::updateC oeffs() in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #5 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" #6 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #4 Foam::fixedFluxPressureFvPatchScalarField::updateC oeffs() in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #5 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" #6 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #7 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam200/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #8 in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" #9 in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" #10 in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" #11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #12 in "/opt/openfoam200/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoam" Aborted ************************************************** ********** |
Dear Matej,
do you still try out my case or your own? Please compare your fvSchemes with a tutorial case like hotRooam. It seem your schemes are wrong for pressure? Bye Thomas |
