Home > Forums > OpenFOAM Running, Solving & CFD
Increasing Square Cavity mesh to 100x100 causes crash. Why?
Old   July 5, 2014, 06:13
Default Increasing Square Cavity mesh to 100x100 causes crash. Why?
Tom
Tom717 is on a distinguished road
Hi, I am a beginner with OpenFOAM and CFD in general.
I am experimenting with the first tutorial, the square cavity. For my first modifications I edited the mesh size. Changing from 20x20 to 40x40 caused no problem. However if I edit blockmeshdict to give me a 100x100 mesh then icoFoam crashes.
I get this:
Courant Number mean: 5.32474e+87 max: 2.58355e+89
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4  Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
 at ??:?
 at ??:?
 at ??:?
 at ??:?
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
 at ??:?
Floating point exception (core dumped)
Can someone explain what is going wrong?
Tom
Tom717 is offline   Reply With Quote
Old   July 6, 2014, 05:23
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Tom,
Notice this at the top of the output you've given?
Originally Posted by Tom717 View Post
The Courant Number should not go over 1.0, otherwise it will likely lead to a divergence and eventually crash.
I strongly suggest that you read the User Guide more carefully and take notes, because in the User Guide, section "2.1.6.2 Changing time and time step" it explains how the mesh resolution relates to the Courant Number and how the "deltaT" value should be adapted to the new mesh resolution.
If you did take this into account, you should have indicated what calculations you made and the "deltaT" value you used
Best regards,
Bruno
Thread Tools
Trackbacks are On
Star CCM Overset Mesh Error (Rotating Turbine) thezack CD-adapco 4 April 26, 2016 02:03
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
[ICEM] Mirror Mesh | Delete duplicate mesh pythag0ra5 ANSYS Meshing & Geometry 6 November 19, 2013 08:35
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
