Wall heat transfer
Old   July 9, 2014, 13:46
Default Wall heat transfer
atlan is on a distinguished road
I would like to solve heat transfer from an air flow through a metal wall to surrounding air without modelling the solid wall thickenss (separate mesh).
The BC would be set as:
Internal wall temperature is calculated
Internal heat transfer coefficient is calculated
Wall thickens and conductivity are assigned
External surrounding temperature is assigned
Is it possible to use for this problem BC externalWallHeatFlux or is there some other BC for this propose? Is there some tutorial solving this problem?
Thanks
atlan is offline   Reply With Quote
Old   July 10, 2014, 08:44
ashwin
ashghan is on a distinguished road
Hello Altan,
The externalWallHeatFlux fits perfectly to your description.
wall
            type            externalWallHeatFluxTemperature;
            kappa           fluidThermo;       // fluidThermo, solidThermo
            //q               uniform 1000;      // heat flux / [W/m2]
            Ta              uniform 300.0;     // ambient temperature /[K]
            h               uniform 10.0;      // heat transfer coeff /[W/K/m2]
            thicknessLayers  (0.1); // thickness of layer [m]
            kappaLayers     (0.05);          // thermal conductivity of
                                               // layer [W/m/K]
            value           uniform 300.0;     // initial temperature / [K]
            kappaName       none;
Note
Only supply \c h and \c Ta, or \c q in the dictionary
ashghan is offline   Reply With Quote
Old   July 11, 2014, 11:09
Thanks for the response. I am now testing this BC with rhoSimpleFoam.
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
how to model heat transfer for the coupled wall jing113cn FLUENT 0 June 22, 2009 03:56
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
