Inclusion of Damping Function in Stochastic Dispersion Model |
July 15, 2014, 00:45 |
India
Rep Power: 13 |
Hi Foamers,
I want to introduce some correction in Stochastic Dispersion Model file StochasticDispersion.C. I have to introduce a damping factor that modifies the particle fluctuation velocity(due to turbulence) near the wall. Following code is from StochasticDispersionRAS.C: Code:
scalar sigma = sqrt(2.0*k/3.0); Code:
scalar sigma=(1-exp(-0.02*yPlus[p.cell()]))*sqrt(2.0*k/3.0); I can calculate yPlus for each cell, using a post processing utility, at t=0. yPlus is then saved in text file in '0' directory of my OpenFOAM case setup. I need to modify the dispersion model code so that it can access the calculated yPlus values as explained above. Can somebody guide me? Regards, Mayank |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
damping function for EARSM model | Vincent | Main CFD Forum | 0 | January 17, 2001 10:41 |
