-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Arithmetic exception (https://www.cfd-online.com/Forums/openfoam-solving/139031-arithmetic-exception.html)
Jalued July 16, 2014 05:52
2 Attachment(s)
For some reason, I am continuing to receive an "Arithmetric exception" error message when I attempt to run any 2D simulation after importing from Pointwise. In order to find the culprit I have gone to the simplest case I could think of: a 2D simulation that mimics the 2DAirfoil tutorial but without the airfoil.
I used Pointwise to construct the parameters which consist of a box that was extruded by 0.05m and given a simple structured mesh, passing checkMesh with flying colours:
PHP Code:
Checking geometry...
Overall domain bounding box (1 1 0) (101 101 0.05)
Mesh (non-empty, non-wedgedirections (1 1 0)
Mesh (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (-3.46598e-21 3.46598e-21 9.19282e-15OK.
Max cell openness 1.08813e-16 OK.
Max aspect ratio 1 OK.
Minimum face area 0.0505051Maximum face area 1.0203.  Face area magnitudes OK.
Min volume 0.0510152Max volume 0.0510152.  Total volume 500.  Cell volumes OK.
Mesh non-orthogonality Max0 average0
    Non
-orthogonality check OK.
Face pyramids OK.
Max skewness 1.01608e-13 OK.
Coupled point location match (average 0OK.
Mesh OK
The 0 and system folders are identical to the 2DAirfoil except for the removal of the wall.
I ran the code through gdb simpleFoam and it exploded within the first iteration:
PHP Code:
smoothSolver:  Solving for UxInitial residual 0.343067, Final residual 1.85346e+13No Iterations 1000
smoothSolver
:  Solving for UyInitial residual 0.00320924, Final residual 2.19375e+11No Iterations 1000
GAMG
:  Solving for pInitial residual 1, Final residual 5.19741e+118No Iterations 1000
time step continuity errors
sum local 2.01405e+117, global = 3.29242e+101cumulative 3.29242e+101
Program received signal SIGFPE
Arithmetic exception.
0x00007ffff4ab9575 in Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Fielddouble> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned charint) () from /opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so
I have no idea what could be wrong with this, as the 2DAirfoil example works perfectly and a similar "laminar flow through a straight pipe" Pointwise to OpenFoam tutorial also works with no issues.
I was unable to attach the pw file or constant folder due to space constraints
Thanks,
Ed
