titanchao |
July 24, 2014 13:36 |
Can I use fvOptions to couple a solid region and a fluid region?
The solid region represents a porous medium. The reason I want to do the coupling is because I need to solve both the thermal energy transport in the fluid and the heat conduction in the porous medium. I intend to use the chtMultiRegionSimpleFoam solver.
(1) Is fvOptions allowed to be used to couple two regions that have different governing equations?
(2) I modified the settings based on the heat exchanger case in the tutorial. Because I want a heat conduction equation to be solved for my porous region (vs. another flow region in the original tutorial case), I modified the fvSchems file to one that's supposed to solve a Laplacian equation only (see the following). Is this correct?
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;//Euler;
gradSchemes
default Gauss linear;
grad(T) Gauss linear;
divSchemes
default none;
laplacianSchemes
default none;
laplacian(K,T) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
T ;
(3) Why does it keep asking for a pressure initial condition for the porous media (solid) region? If it only solves a heat conduction equation, why is pressure field needed? chao@ChaoCFDLinux:~/OpenFOAM/chao-2.3.0/run/oneChannePorousMediaHT$ chtMultiRegionSimpleFoam
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : chtMultiRegionSimpleFoam
Date : Jul 24 2014
Time : 09:52:16
Host : "ChaoCFDLinux"
PID : 13319
Case : /home/chao/OpenFOAM/chao-2.3.0/run/oneChannePorousMediaHT
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region domainFluid for time = 0
Create solid mesh for region exRegionSolid for time = 0
*** Reading fluid mesh thermophysical properties for region domainFluid
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type laminar
Adding to ghFluid
Adding to ghfFluid
Selecting radiationModel none
Adding fvOptions
Creating finite volume options from fvOptions
Selecting finite volume options model type constantHeatTransfer
Source: fluidTosolid
- applying source for all time
- selecting inter region mapping
Creating mesh-to-mesh addressing for domainFluid and exRegionSolid regions using cellVolumeWeight
Overlap volume: 1.10097e-05
Selecting finite volume options model type interRegionExplicitPorositySource
Source: porosityBlockage
*** Reading solid mesh thermophysical properties for region exRegionSolid
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/chao/OpenFOAM/chao-2.3.0/run/oneChannePorousMediaHT/0/exRegionSolid/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
(4) It appears the fvOptions has to be defined respectively for both regions, the fluid and the porous region (solid). Does it matter which one is the master region?
(5) Anyone has solved similar problems? And other suggestions to solve the problem?
Thank you so much!
