Home > Forums > OpenFOAM Running, Solving & CFD
Energy balance
Old   August 6, 2014, 13:13
Default Energy balance
atlan is on a distinguished road
Hi all,
Can anyone advise me please how to check the energy balance in a simple straight tube?
I have tube with one inlet and one outlet and one wall. At the inlet I impose constant temperature and at the wall a heat flux.
When I use wallHeatFlux utility to calculate the power it shows at the inlet and outlet values in order lower than the heat loss at the wall.
However, if I roughly estimate the power from the mass flow rate and the temperature difference between inlet and outlet (cp*m*dt) it looks similar to the heat loss trough the wall. But the problem is that there is already temperature profile at the inlet and I cannot set the outlet temperature exactly.
The solver is buoyantSimpleFoam.
Thanks
Atlan
atlan is offline   Reply With Quote
Old   August 7, 2014, 04:59
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I have no experience with "wallHeatFlux" utility, but just from the wording: Maybe it just calculates the heat flux as a spatial derivative of temperature times the heat conductivity, because that is how you would calculate the heat flux at a wall:
q=lambda*dT/dy.
At the inlet and outlet you don't have a wall but the moving fluid. Thus, "q" gets an additional component by the heat that is transported by the moving fluid rho * u * E0.
This could be the reason the balance doesn't work how you do it, because heat conduction at inlet and outlet ist just way less than convective heat transport.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 7, 2014, 09:54
You are right. I have realized, it is not possible to use the wallHeatFlux utility for inlet and outlet. It is applicable only for walls.
Thread Tools
Trackbacks are On
Natural convection, problems with total energy balance MdoNascimento STAR-CCM+ 0 March 13, 2014 13:15
volumetric reaction and energy balance? m.beh FLUENT 1 October 17, 2011 17:21
Energy balance error with high prandtl numbers. David_010 OpenFOAM Running, Solving & CFD 0 January 20, 2011 06:21
energy balance zdz198728 Main CFD Forum 1 November 19, 2009 01:07
HELP needed: Energy balance in gaseous combustion James Willie FLUENT 11 August 10, 2005 04:58
