[SOWFA] Scale down on SOWFA Actuator Line Turbine Model
Old   August 9, 2014, 18:56
Default Scale down on SOWFA Actuator Line Turbine Model
Korawin Sriniratsai
korawin10287 is on a distinguished road
Hello forum
I have a question regarding the Actuator Line Turbine Model in SOWFA code.
I was wondering that is it possible to scale down the size of blades and its domain in this model ? eg. 100 times smaller than the real scale [(30 30 10) blockMesh size]. From my understanding, it is required 21 hours running time in 64 processors machine.
I also tried to modified the boundary condition, meshing, and NREL 5 MW turbine data to satisfy the scale down requirement. Unfortunately, it does not work and the forces does not appear in the final output.
Thank you very much in advance.
Kind Regards,
Korawin
korawin10287 is offline   Reply With Quote
nrel, scale, sowfa, turbine blade, wind
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Water turbine model FMOR CFX 30 May 9, 2012 07:23
Zero equation turbulence model velocity scale Kim CFX 2 February 25, 2009 09:56
gas turbine combustor model - HELP! Phil Main CFD Forum 5 April 10, 2007 11:54
Wind turbine model Simon Main CFD Forum 3 August 19, 2005 07:07
