August 13, 2014, 10:49 |
Blade simulation
Guido Bonalumi
Rep Power: 12 |
Hi everyone,
for my thesis I am trying to simulate a set of blade in a wind tunnel (precisely just one blade with periodic condition). I have already create my own mesh with PointWise but I am struggling with OpenFoam. I was told to start with a simpleFoam tutorial, one which uses a two equations model, but I am not sure that is the right choice. I have an high Reynolds number (around 10^5), with an isoentropic Mach number of 0.2 downstream of the blade. At the inlet I have a uniform velocity of 21 m/s, at the outlet a uniform pressure. There is a simmetry condition on a plane located at the midspan so the mesh is splitted in two half. The two lateral surfaces have periodic (cyclic in OpenFoam, right?) condition. From which tutorial should I start? Can you help me in particular with the boundary conditions (epsilon and k)? Thanks in advance! |
Discrete event simulation vs. fixed time (discrete time simulation) | jenjon | FLUENT | 0 | March 10, 2013 06:58 |
blade induced flow simulation | Mehran | OpenFOAM | 1 | October 27, 2011 03:24 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
could anybody help with Ansys blade simulation? | fredfalcao | Main CFD Forum | 0 | December 9, 2009 05:49 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 13:46 |
