Home > Forums > OpenFOAM Running, Solving & CFD
Beowulf cluster open foam
Old   August 18, 2014, 10:54
Angry Beowulf cluster open foam
nfo
Nfo
nfo is on a distinguished road
I am creating a cluster with ubuntu 12.04 tls and I have done all the steps in the manual I found on this forum. The problem I have is that when doing the test that appears in the manual, the executable does not work, and which is not the problem. I get this error:
ru @ master: ~ $ mpirun np 4 --hostfile machines --rankfile rankfile interFoam -Parallel> log &
[1] 4575
ru @ master: ~ $ -------------------------------------------- ------------------------------
mpirun was unable to launch the specified application as it Could not find an executable:
Executable: interFoam
Node: nodo01
while attempting to start process rank 2.
no longer continue, not if the problem is in the cluster, the command .... someone help me ???
The version of openfoam I am using is 2.3.0
Thank you for help!
nfo is offline   Reply With Quote
Old   September 1, 2014, 00:51
liyu
ahliyu is on a distinguished road
you can try this command:
mpirun –hostfile machines –np 12 /home/inet107/OpenFoam/OpenFoam-2.3.0/bin/foamExec ico22968 -parallel
ahliyu is offline   Reply With Quote
Old   September 1, 2014, 03:47
nfo
Nfo
thanx for help.
and I resolved the problem, I was in the bashrc file, and I had to put the path / opt / openfoam230 / ect / bashrc in the first line of the file. Before you put it at the end and did not work me.
Thank you
openfoam cluster beowulf
Thread Tools
Trackbacks are On
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Swak4Foam funkyDoCalc with OF2.3 massflow NiFl OpenFOAM 8 March 24, 2014 21:06
Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Native Meshers: blockMesh 43 February 18, 2014 03:42
non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Native Meshers: blockMesh 7 April 17, 2013 05:42
Running Foam on multiple nodes (small cluster) Hisham OpenFOAM Running, Solving & CFD 4 June 11, 2012 13:44
