August 18, 2014, 10:54 |
Beowulf cluster open foam
Nfo
I am creating a cluster with ubuntu 12.04 tls and I have done all the steps in the manual I found on this forum. The problem I have is that when doing the test that appears in the manual, the executable does not work, and which is not the problem. I get this error:
ru @ master: ~ $ mpirun np 4 --hostfile machines --rankfile rankfile interFoam -Parallel> log & [1] 4575 ru @ master: ~ $ -------------------------------------------- ------------------------------ mpirun was unable to launch the specified application as it Could not find an executable: Executable: interFoam Node: nodo01 while attempting to start process rank 2. -------------------------------------------------- ------------------------ no longer continue, not if the problem is in the cluster, the command .... someone help me ??? The version of openfoam I am using is 2.3.0 Thank you for help! |
September 1, 2014, 00:51 |
liyu
Rep Power: 12 |
you can try this command:
mpirun –hostfile machines –np 12 /home/inet107/OpenFoam/OpenFoam-2.3.0/bin/foamExec ico22968 -parallel |
September 1, 2014, 03:47 |
Nfo
thanx for help.
and I resolved the problem, I was in the bashrc file, and I had to put the path / opt / openfoam230 / ect / bashrc in the first line of the file. Before you put it at the end and did not work me. Thank you |
openfoam cluster beowulf |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Running Foam on multiple nodes (small cluster) | Hisham | OpenFOAM Running, Solving & CFD | 4 | June 11, 2012 13:44 |
