August 27, 2014, 03:05 |
libOpenFOAM Library not found
Shabir Mohamed
Rep Power: 11 |
I am trying to use swak4Foam with FOAM_EXTENDED 3.1. I have downloaded swak4foam and run configured it using ./Allwmake. I am trying to run an example case using swak4foam and I included the following lines in the controlDict file: libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" ); However when I run blockMesh I am getting the warning that libOpenFOAM.so is not found. I checked in my $FOAM_USER_LIBBIN and it is not there.. --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 85 could not load libOpenFOAM.so: cannot open shared object file: No such file or directory Can someone tell me what is wrong???? |
August 27, 2014, 03:18 |
libOpenFOAM ----> libfoam???
Shabir Mohamed
Rep Power: 11 |
I tried searching around a bit and I have a doubt???
In OpenFOAM 2.3 in the OpenFOAM libs directory: i.e: opt/openfoam230/platforms/linux64GccDPOpt/lib/ there is a file named ---> libOpenFOAM.so but in FOAM_EXTENDED 3.1, it its libs directory: i.e: foam/foam-extend-3.1/lib/linux64GccDPOpt this file is not there but there is a file with the name ----> "libfoam.so" Are these two the same files with different naming conventions for OpenFOAM 2.3 and FOAM_EXTENDED 3.1?????? |
August 28, 2014, 16:11 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: http://sourceforge.net/p/openfoam-ex...e/ReleaseNotes
blockmesh, library, openfoam |
Installing OpenFoam on windows 7-64 | Dadou | OpenFOAM Installation | 10 | February 11, 2014 16:20 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
