Home > Forums > OpenFOAM Running, Solving & CFD
Oscillation problems simulating a turbulent diffusion flame
Old   August 28, 2014, 04:53
Default Oscillation problems simulating a turbulent diffusion flame
phico is on a distinguished road
Hello everyone,
I'm trying to model a turbulent diffusion flame using the OpenFOAM solver flameletFoam. It's a transient solver based on rhoReactingFoam and I'm using it to perform RANS-simulations with k-epsilon-model.
At the beginning I used a coarse grid and everything worked fine. After that I tried to refine the grid which has led to oscillations in my axial temperature profile. ParaFoam shows an oscillating pressure, too. Moreover, the residuals for pressure don't look really good. I added screenshots showing my mesh, the temperature profile and the residuals for p.
In this particular case, the grid has about 25000 cells. I think thats not much according to a combustion chamber with a length of 1000 mm and a diameter of 700 mm. The thin pipe on the left side represents the jet. I think this is the part where the problem is caused. I tried to remove it and used groovyBC to define a fully developed pipe flow and everything worked fine. Unfortunately, the results are not satisfying. Furthermore, I tried to change the boundary conditions, but this did not help.
I don't know how to solve my problem, perhaps you have some ideas. Thank you!
phico
phico is offline   Reply With Quote
Old   September 2, 2014, 02:25
Sorry for posting again, but I need to fix this problem and I still don't have a clue how to do that... really no one here who can help?
Thread Tools
Trackbacks are On
Simulating diffusion flames with fireFoam babakflame OpenFOAM Programming & Development 1 February 9, 2013 04:21
FVM for diffusion problem or dispersive problems? Wen Main CFD Forum 0 February 22, 2006 14:34
Problems with a diffusion flame Doctor Blade Main CFD Forum 6 September 14, 2004 05:37
Simulating laminar premixed flame Subhash FLUENT 0 August 17, 2004 00:46
Flotran problems with compressible turbulent flows Ross Main CFD Forum 1 September 27, 2002 13:08
