Internal Flow Not Enough Turbulent - (pisoFoam, LES, sub grid models) |
August 1, 2014, 11:03 |
Rep Power: 12 |
Hi everybody,
I have a question which is tricky for months. I would be really appreciate your shares and your answers. I want to simulate an internal flow through an injector. I use pisoFoam, LES and I tried oneEqEddy and mixed Smagorinsky sub-grid models. The trouble I have is the flow is not at all turbulent which is the situation I waited for. Here you have my input files for mixed Smagorinsky: ======================= In folder 0 ======================= === p dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type zeroGradient; } Outlet { type fixedValue; value uniform 0; } Wall { type zeroGradient; } } === U dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { Inlet { type turbulentInlet; referenceField uniform (0 0 7.1); fluctuationScale (0.02 0.02 0.02); value uniform (0 0 7.1); alpha 0.5; } Outlet { type zeroGradient; } Wall { type fixedValue; value uniform (0 0 0); } } ======================= In folder constant ======================= === LESProperties LESModel mixedSmagorinsky; delta cubeRootVol; printCoeffs on; mixedSmagorinskyCoeffs { filter simple; ce 1.05; } cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } === turbulenceProperties simulationType LESModel; ======================= In folder system ======================= === fvScheme ddtSchemes { default backward; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; div((dev((((surfaceSum((magSf*interpolate(sqr(U))) )|surfaceSum(magSf))-sqr((surfaceSum((magSf*interpolate(U)))|surfaceSum (magSf))))+(((0.666667)*((0.5*((surfaceSum((magSf* interpolate(magSqr(U))))|surfaceSum(magSf))-magSqr((surfaceSum((magSf*interpolate(U)))|surface Sum(magSf)))))+((((2*ck)|ce)*sqr(delta))*magSqr(de v(symm(grad(U)))))))-(nuSgs*twoSymm(grad(U))))))+(-nuEff*dev(twoSymm(grad(U)))))) Gauss linear; // div((nu*dev(T(grad(U))))) Gauss linear; div((grad(U)&U)) Gauss linear; div(phi,k) Gauss limitedLinear 1; div(phi,B) Gauss limitedLinear 1; div(B) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } === fvSolution solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } pFinal { $p; smoother DICGaussSeidel; tolerance 1e-06; relTol 0; } "(U|k|B|nuTilda)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 3; } Once again, all your ideas are welcome and thank you in advance! vut |
August 9, 2014, 14:25 |
did you find your answer? I have a same question
If you found it can you please let me know about it Regards, Mostafa |
August 29, 2014, 02:37 |
Rep Power: 12 |
Dear Mostafa,
I do not have the answer for now. I hope somebody knows how to solve it. I myself try to change some parameters to obtain a more turbulent flow inside the injector. Without doubt, I give you further information if the problem is fixed. Best regards, vut |
August 29, 2014, 02:48 |
hi,
I've found the solution. at first I defined a variable deltaT in a way that the Courant number doesn't exceed Co=0.6. Then, I let it solve for a long time to reach a fully-developed turbulent flow (in my case, I should reach a fully-developed condition). actually the c_k and c_e which lead to C_S are very important, you should specify them in a way that the turbulent dissipation decreases and eddies formed in flow don't decay! hope it helps you Regards, Mostafa |
August 29, 2014, 05:38 |
Rep Power: 12 |
Thank you, Mostafa for replying me.
Can you give more details of the way you modify C_s (or C_k and C_e)? Did you mean we can do so by reducing Ce in LESProperties file? mixedSmagorinskyCoeffs { filter simple; ce 1.05; } May you attach your LESProperties, fvSolution and fvSystem files? I am not yet so confident with OpenFOAM. Thanks in advance, vut |
September 15, 2014, 14:18 |
#6 | |
Ali Shamooni
Rep Power: 15 |
Could you pls explain more 1. What is ur case? A channel or pipe? 2. An estimate dimension. And mesh size 3. What is ur boundary? Periodic? Or inlet, outlet and wall 4. And the most important, what do u mean by "long time" |
Velocity curve in channel flow by pisoFoam and LES | mxylondon | OpenFOAM Verification & Validation | 9 | June 21, 2015 07:28 |
LES of Turbulent channel flow | chivaee | Main CFD Forum | 6 | July 21, 2012 19:38 |
spectrum: LES of a turbulent channel flow finally goes to turbulent | liu | OpenFOAM Running, Solving & CFD | 6 | November 1, 2011 01:00 |
Turbulent channel flow by LES | Paul | Main CFD Forum | 14 | July 6, 2009 04:02 |
Gas flow in vortex tube - LES and grid resolution | bernarde | Main CFD Forum | 1 | March 26, 2009 10:50 |
