dynamic mesh to twoPhaseEulerFoam correctPhi
1 Attachment(s)
I have been trying to introduce dynamic mesh abilities to twoPhaseEulerFoam solver. I have taken a look into similar solvers like interFoam and pimpleFoam tried to apply it on the twoPhaseEulerFoam solver. Basically, I have included dynamicFvMesh.H, createDynamicFvMesh.H, and correctPhi.H. After some adjustments, I did succeed with compiling a new solver twoPhaseEulerDyMFoam (used wclean wmake).
The solver seem to work but needed to edit units in correctPhi.H: Code:
dimensionedScalar rAUf("rAUf", dimTime/dimMass*dimVolume, 1.0); // dimensionedScalar rAUf("rAUf", dimTime/rho.dimensions() |
Hey Potac
Did you have success with this in the end? It is something which I also was planning to work on soon. |
I work on it also. I want to simulate a screw conveyor, so I need a rotating mesh. Do you have successfully implemented this solver? Best regards |
twoPhaseEulerDyMFoam - First try
1 Attachment(s)
Here's a first try of twoPhaseEulerDyMFoam. The code is compiling, but it doesn't work. But, the same model with twoPhaseEuler does not work either. I think that the problem is with the cyclicAMI patch. Any help and feedback would be appreciated. Thank you, |
I work on it also. I need to simulate a moving boundary with multiphase flow inside. Do you have successfully implemented this solver? Best regards |
I am working on this problem as well. Did you manage to create the solver? Thanks in advance |
I'm really interested in this DyM version of the solver. Did you succeed? i would like to set vibrations to the simulation by making the entire mesh moving up and down at 50hz.
Hi Pisolino,
I partially managed to implement the dynamic library into twoPhaseEulerFoam. There is still some work to be done but if you want I can send you the current version. The solver works but I had to remove some flux due to the particle interaction |
Hi adrien, i'm not a coder but since i'm interested in such solver i can give my best to help you to conclude the solver. Let me know how to go on with the development of such solver. Andrea |
You can give me your email, I'll send you the folder
i sent you a PM with the mail address
Hi adrien, I am also very interested in your solver about the twoPhaseEulerFoam, could you also send me a copy of it? |
Dynamic mesh in two fluid
Hi can you share with your code? I need to apply dynamic mesh in twoPhaseEulerFoam. I need some hints, I appreciate if you help me about that.
Could you share code with me? I am working with two phases and also trying to implement dynamicMesh in twoPhaseEulerFoam. Unsuccessful so far. Thanks. |
Hello Adrien, I am trying to simulate multiphase fluid pumping. I have not yet succeeded in modifying twoPhaseEulerFoam for this task, could you share your code with me? Thanks. |
twoPhaseEulerfoam with dynamic Mesh
3 Attachment(s)
I tried to implement dynamic mesh in twoPhaseEulerFoam based on interDyMFoam. The application compiles, but the results are not coherent. I believe that the corrections of the fluxes (phi1 and phi2) are missing. I'm working with a incompressible case. Would anyone have a suggestion to fix the app? Thank you.
My main question is about the calculation of relative fluxes, the solver has several (phi1,alphaPhi1,alphaRhoPhi1,phi2,alphaPhi2,alphaR hoPhi2), do I need to calculate all? Attachment 78053 Attachment 78054 Attachment 78055 |
Could you please share also with me the version of the twoPhaseEulerFoam with dynamic mesh refinement that you have available? |
I am working on the DyM version of twophaseEulerFoam without success yet. Could we have some talk about this topic for some hints. I appreciate that! JZ |
my email is 710347000@qq.com |
