Running icoFsiElasticNonLinULSolidFoam in parallel |
September 23, 2014, 05:16 |
Yann
Rep Power: 26 |
Hello all,
I've recently started to work on FSI with icoFsiElasticNonLinULSolidFoam. I'm able to run the HronTurekFsi tutorial on a single processor but fail to run it on parallel with the AllrunPar script. The simulation starts just fine but crashes after a while with a Floating point exception error. Anyone achieved to run this tutorial in parallel? Is there some trick or something to add in the AllrunPar? Thanks Yann |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 05:24 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 08:53 |
problem in running parallel: ./Allrun: 62: shift: can't shift that many | adambarfi | OpenFOAM Running, Solving & CFD | 10 | May 11, 2015 09:31 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
