Setting up Parallel Simulations of Dynamic Mesh
Old   September 23, 2014, 19:18
Default Setting up Parallel Simulations of Dynamic Mesh
Will
willzyba is on a distinguished road
I'm find setting up new models for waveFoam and waveDyMFoam (which are essentially icoFoam and IcoDyMFoam) to be a process of random luck.
The process of creating a Mesh, Assigning values to the mesh (like Alpha levels and initial velocities), and splitting it across processors seems to require a lot more care and just when I think I get it - it doesn't.
To give an illustration, our Allrun script has the following form
#!/bin/sh
. $WM_PROJECT_DIR/bin/tools/RunFunctions
runApplication surfaceFeatureExtract
runApplication blockMesh
runApplication decomposePar
runParallel snappyHexMesh 40 -overwrite
# reconstruct
runApplication reconstructParMesh -mergeTol 1e-6 -constant
\rm -rf 0
\cp -r 0.org 0
rm -rf processor*
mv log.decomposePar log.decomposePar1
runApplication setWaveField
runParallel wave[DyM]Foam 40
parReconstructPar -n 20
Note we use either waveDyMFoam or waveFoam
I hate this script, since we split the mesh for snappyHexMesh, pull it all back together just to assign velocities and water levels to all the cells (with setWaveField) and then split it again. However, its the only way I get it to work consistently. Has anyone managed to get setWaveField to work sensible in parallel - which I know it can do.
Another issue that perplexes me, is that I see in many example the following lines or an appropriate variant, at the bottom of each file within 0.org
    "procBoundary.*"
        type            processor;
        value           uniform (0 0 0);
What does this do? And when do we need these lines and when not. With our Allrun script above, it seems to work without.
As an example in 0.org/alpha.water contains
|  \\    /   O peration     | Version:  1.5-dev                               |
|   \\  /    A nd           | Revision: 1740                                  |
|    \\/     M anipulation  | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.water;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    bottom
        type            zeroGradient;   // no flow through boundary
    backWall
        type            zeroGradient;
    inlet
        type            waveAlpha;
        refValue        uniform 0;
        refGrad         uniform 0;
        valueFraction   uniform 1;
        value           uniform 0;
    outlet
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    ccell
        type            zeroGradient;
    "procBoundary.*"
        type            processor;
Thanks in advance.
willzyba is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Reconstruction after parallel run with dynamic mesh refinement sebonator OpenFOAM 9 June 14, 2018 07:38
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
