simpleFoam: switching flow direction with kOmegaSST RAS Model |
September 2, 2014, 15:25 |
Jason G.
Rep Power: 16 |
I have been looking at pressure drops for internally bounded, steady-state, incompressible fluid flow cases with the simpleFoam solver. Typically, I specify a velocity at the entrance to the fluid domain and a reference pressure of 0 at the exit of the fluid domain.
A new case I am working on requires me to specify a velocity at the exit and a reference pressure at the entrance. I have been able to successfully do this with laminar assumptions, but as soon as I attempt to switch to the kOmegaSST turbulence solver I run into convergence issues. It appears the kinetic turbulence values become discontinuous near the entrance. Any help and/or recommendations are greatly appreciated. Below are the current BC's I am implementing: "intialConditions" Code:
flowVelocity (0 0 165.760612715333); pressure 0; turbulentKE 194.091657099187; turbulentOmega 1731.03910939215; kinematicvis nu [ 0 2 -1 0 0 0 0 ] 0.0398447454916618; // in^2/s density 0.00007839; // Value of the density(sslug/in^3) pstatic = lbf/in^2 //RAS PROPERTIES RAS_MODEL kOmegaSST; //kOmegaSST; //laminar; turb_on_off on; //on #inputMode merge Code:
#include "initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { outlet_1 { type inletOutlet; inletValue $internalField; value $internalField; } inlet_1 { type fixedValue; value $internalField; } boundary { type zeroGradient; } symmetry { type symmetryPlane; } } Code:
#include "initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { outlet_1 { type outletInlet; outletValue $flowVelocity; value $flowVelocity; } inlet_1 { type outletInlet; outletValue $internalField; value $internalField; } boundary { type fixedValue; value $internalField; } symmetry { type symmetryPlane; } } Code:
#include "initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $turbulentKE; boundaryField { outlet_1 { type fixedValue; value $internalField; } inlet_1 { type outletInlet; outletValue $internalField; value $internalField; } boundary { type kqRWallFunction; value $internalField; } symmetry { type symmetryPlane; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet_1 { type calculated; value uniform 0; } outlet_1 { type calculated; value uniform 0; } boundary { type nutLowReWallFunction; value uniform 0; } symmetry { type symmetryPlane; } } Code:
#include "initialConditions" dimensions [0 0 -1 0 0 0 0]; internalField uniform $turbulentOmega; boundaryField { outlet_1 { type fixedValue; value $internalField; } inlet_1 { type outletInlet; outletValue $internalField; value $internalField; } boundary { type omegaWallFunction; value $internalField; } symmetry { type symmetryPlane; } } |
September 25, 2014, 07:26 |
Joachim Herb
Rep Power: 21 |
You might try the fixedMean boundary condition for the velocity, k and omega at the outlet (assuming the the specified flow is going "outwards").
Then you do not enforce a constant value over the whole outlet but just the (area averaged) mean for the three quantities. So the turbulent block profile within your flow domain is not destroyed at the outlet. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model | us | FLUENT | 5 | April 5, 2011 02:29 |
Ho to model the flow in a Regenerator | alexandrepereira | OpenFOAM Running, Solving & CFD | 2 | August 25, 2010 17:35 |
