fvSchemes for Skewed and nonOrthogonal Mesh?
Like Tree2Likes
  • 1 Post By RodriguezFatz
  • 1 Post By Tushar@cfd
Old   September 30, 2014, 05:53
Default fvSchemes for Skewed and nonOrthogonal Mesh?
Mubashir Ali
mooby is on a distinguished road
Send a message via Skype™ to mooby
I have prepared a Mesh for a UAV using snappyHEX. the mesh passed the check mesh but highest non orthogonality is around 85 but average is pretty less and max skewness is 11. I wish to know what schemes I should be using to obtain acceptable results with this kind of mesh. I am using the default schemes settings in fv schemes
mooby is offline   Reply With Quote
Old   October 10, 2014, 13:35
PHS- is on a distinguished road
85 seems pretty high so you should first try to decrease it in the mesh if you can.
Otherwise, you can try to set the laplacianSchemes to linear corrected or to linear limited 0.5
For more info on numerical schemes available, check out http://www.openfoam.org/docs/user/fvSchemes.php
PHS- is offline   Reply With Quote
Old   October 13, 2014, 06:51
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
You need "linear uncorrected" not "corrected" for the laplacian if the mesh is bad. Also, start with the safest (upwind) for all convective parts and "Euler" for ddt. "Gauss linear" for all gradients.
pavlossemelides likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 4, 2014, 09:25
Default fv-Schemes in general
Tobias Adam
Tobias Adam is on a distinguished road
Hey everyone
I try to find an explantation to the fv-schemes.
I know how to use the main schemes. But I like to understand all schemes from this list.
Does anyone know where to find information about these.
Information could be anything like, the mathematical explanation the fv-schemes ( still I don´t understand c++) or descriptions about when to use which scheme.
The schemes I want to know about are listed in this document:
https://docs.google.com/document/d/1...it?usp=sharing
Tomorrow I´m going to ask someone to help me with C++, but I would be happy for each kind of information :-)
Best regards Tobi
Tobias Adam is offline   Reply With Quote
Old   December 4, 2014, 14:37
Hao Chen
hchen is on a distinguished road
Why when the mesh is bad Gauss uncorrected is needed?
hchen is offline   Reply With Quote
Old   December 4, 2014, 23:54
T. Chourushi
Tushar@cfd is on a distinguished road
Hello Everyone,
I think this problem is discussed many times on forum. The best answer for the same is answered in the following post:
http://www.cfd-online.com/Forums/ope...implefoam.html
For more information refer the weblink:
Best Luck!
RodriguezFatz likes this.
Tushar@cfd is offline   Reply With Quote
Old   December 5, 2014, 02:19
Philipp
But you need to pay attention in that link. They are talking about two different things. The first answer is about non-orthogonal correction of simple algorithm, which is indeed not needed for accuracy, if the solver converges.
Your question was about a correction of the laplace operator. This is something different. Just keep in mind that uncorrected is bounded and corrected is unbounded.
openfoam
[snappyHexMesh] orthogonal cells marked as nonOrthogonal colinB OpenFOAM Meshing & Mesh Conversion 2 January 22, 2014 09:24
XiFoam floating point error..mut error? achinta OpenFOAM 8 July 31, 2012 04:48
fvScheme and NonOrthogonal Correctors Andrea_85 OpenFOAM 27 April 14, 2011 11:35
Circular Cylinder at low Reynold number mesh and non orthogonal corrections kassiotis OpenFOAM Running, Solving & CFD 6 May 15, 2008 06:07
When and how to apply nonOrthogonal correctors vvqf OpenFOAM Running, Solving & CFD 1 March 22, 2006 05:21
