Failed to simulate wind turbine based on wingmotion tutorial with pimpleDyMFoam |
July 8, 2014, 05:12 |
Carl Liu
Rep Power: 11 |
Hi, everyone
I am quite new to OF and trying to simulate a horizontal axis wind turbine with wingmotion tutorial in pimpleDyMFoam. Any help or suggestion would be greatly appreciated! PS: I am using OF230. PPS: The cases are over 100k and can be downloaded from the link. My thought is to treat the wind turbine as a rotating rotor which is driven by the inlet flow. This rotor is constrained by a axis and a fixed point (= its geometry center), and its rotation is restrained by a damper. But the integration crashes after several time steps. You can check this by running the "Case1" here. My guess is that the meshes rotate with the wind turbine and some are squeezed too much as seen in "screenshot1.png" Attachment 32057 So I turned to AMI which would work for rotation objects. I modified the propeller tutorial based on my limited understanding and it is the 'Case2' here. The meshes are generated rightly but it seems the initial conditions are not right as the flow is nearly zero during the whole integration. And the wind turbine is not rotating any more... Any suggestions? Thanks in advance! ------------------------ The error mesg is similar, I dont know how to fix it. Any advice? thanks a lot! Code:
[power:…ingMotion2D_pimpleDyMFoam]$ cat log /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : pimpleDyMFoam Date : Jul 08 2014 Time : 15:57:24 Host : "power" PID : 28690 Case : /home/gohome/Study/openfoam230/incompressible/pimpleDyMFoam/wingMotion/wingMotion2D_pimpleDyMFoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: sixDoFRigidBodyMotion Translational constraint tensor (0 0 0 0 0 0 0 0 0) Rotational constraint tensor (1 0 0 0 0 0 0 0 0) PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading field p AMI: Creating addressing and weights between 15678 source faces and 15822 target faces AMI: Patch source sum(weights) min/max/average = 0.5010934349, 1.474859027, 1.000194821 AMI: Patch target sum(weights) min/max/average = 0.09389027004, 1.168376359, 0.9990085188 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Reading/calculating face velocity Uf No finite volume options present Courant Number mean: 0.0007921648591 max: 0.1782758803 Starting time loop Courant Number mean: 0.0007921648591 max: 0.1782758803 deltaT = 1e-05 Time = 1e-05 Restraint rotationDamper: moment (-0 -0 -0) Centre of mass: (0 -0.053 -0.089) Linear velocity: (0 0 0) Angular velocity: (-1.276190562e-05 0 0) AMI: Creating addressing and weights between 15678 source faces and 15822 target faces AMI: Patch source sum(weights) min/max/average = 0.5010934349, 1.474859027, 1.000194821 AMI: Patch target sum(weights) min/max/average = 0.09389027004, 1.168376359, 0.9990085188 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.01332130797, No Iterations 6 time step continuity errors : sum local = 2.281601699e-09, global = -7.114131082e-11, cumulative = -7.114131082e-11 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.9999999971, Final residual = 0.01170120474, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0150662549, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.01508156985, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.006603088823, No Iterations 7 time step continuity errors : sum local = 1.132741528e-09, global = -7.336139937e-11, cumulative = -1.445027102e-10 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.1250681082, Final residual = 3.712558956e-07, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.2256651087, Final residual = 6.60532103e-07, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.2263188243, Final residual = 6.689522455e-07, No Iterations 4 GAMG: Solving for p, Initial residual = 0.4776872574, Final residual = 5.675631116e-08, No Iterations 20 time step continuity errors : sum local = 1.899086223e-14, global = -3.752338358e-15, cumulative = -1.445064625e-10 smoothSolver: Solving for omega, Initial residual = 6.276897656e-05, Final residual = 6.053036459e-07, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1, Final residual = 7.811010559e-07, No Iterations 3 ExecutionTime = 12.28 s ClockTime = 12 s Courant Number mean: 0.0007924403218 max: 0.1849597784 deltaT = 1e-05 Time = 2e-05 Restraint rotationDamper: moment (2.552381125e-08 -0 -0) Centre of mass: (0 -0.053 -0.089) Linear velocity: (0 0 0) Angular velocity: (-1.235007842 0 0) AMI: Creating addressing and weights between 15678 source faces and 15822 target faces AMI: Patch source sum(weights) min/max/average = 0.5010934349, 1.474859027, 1.000194821 AMI: Patch target sum(weights) min/max/average = 0.09389027004, 1.168376359, 0.9990085188 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.01120405059, No Iterations 2 time step continuity errors : sum local = 3.999152841e-14, global = -3.703542962e-15, cumulative = -1.445101661e-10 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.08762828166, Final residual = 0.0002195620438, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.2149869513, Final residual = 0.0005942728825, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.2522776861, Final residual = 0.0007084008448, No Iterations 1 GAMG: Solving for p, Initial residual = 0.4194730027, Final residual = 0.002164392235, No Iterations 6 time step continuity errors : sum local = 1.333936083e-09, global = 1.287276558e-10, cumulative = -1.578251025e-11 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.01067637411, Final residual = 1.592974448e-07, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.04016122951, Final residual = 9.17971348e-07, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.04743291374, Final residual = 1.178594246e-07, No Iterations 4 GAMG: Solving for p, Initial residual = 0.4885660006, Final residual = 6.938117308e-08, No Iterations 19 time step continuity errors : sum local = 3.235710057e-14, global = 3.14924399e-15, cumulative = -1.5779361e-11 smoothSolver: Solving for omega, Initial residual = 6.627998761e-06, Final residual = 4.274861074e-10, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.9795699155, Final residual = 7.435090749e-07, No Iterations 3 ExecutionTime = 20.74 s ClockTime = 21 s Courant Number mean: 0.0007924656356 max: 0.2009499482 deltaT = 1e-05 Time = 3e-05 Restraint rotationDamper: moment (0.002469990161 -0 -0) Centre of mass: (0 -0.053 -0.089) Linear velocity: (0 0 0) Angular velocity: (-2.244016598 0 0) AMI: Creating addressing and weights between 15678 source faces and 15822 target faces AMI: Patch source sum(weights) min/max/average = 0.5010851984, 1.474838948, 1.000167963 AMI: Patch target sum(weights) min/max/average = 0.09385795596, 1.168373659, 0.9990083961 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.008189369104, No Iterations 6 time step continuity errors : sum local = 5.587740237e-11, global = 6.714291038e-13, cumulative = -1.51079319e-11 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.01169287521, Final residual = 3.289517688e-05, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.04629253508, Final residual = 0.0001506767796, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.06114240829, Final residual = 0.0002021080614, No Iterations 1 GAMG: Solving for p, Initial residual = 0.6402490417, Final residual = 0.004007032311, No Iterations 5 time step continuity errors : sum local = 1.103559705e-09, global = -7.064827283e-11, cumulative = -8.575620473e-11 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.002485534071, Final residual = 4.017024319e-07, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.01193583705, Final residual = 2.926351742e-07, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.01718045466, Final residual = 4.354358227e-07, No Iterations 3 GAMG: Solving for p, Initial residual = 0.4945616154, Final residual = 6.032139435e-08, No Iterations 21 time step continuity errors : sum local = 1.158522461e-14, global = -2.282932827e-15, cumulative = -8.575848766e-11 smoothSolver: Solving for omega, Initial residual = 6.431649157e-06, Final residual = 3.787475548e-10, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.3114458663, Final residual = 2.366442508e-07, No Iterations 3 ExecutionTime = 29.57 s ClockTime = 30 s Courant Number mean: 0.0007964539046 max: 0.1759835946 deltaT = 1e-05 Time = 4e-05 Restraint rotationDamper: moment (0.002018043034 -0 -0) Centre of mass: (0 -0.053 -0.089) Linear velocity: (0 0 0) Angular velocity: (-2.030410901 0 0) AMI: Creating addressing and weights between 15678 source faces and 15822 target faces AMI: Patch source sum(weights) min/max/average = 0, 1.474822556, 1.000108614 AMI: Patch target sum(weights) min/max/average = 0.09383137474, 1.168371466, 0.9990082437 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.01490658934, No Iterations 5 time step continuity errors : sum local = 1.862936667e-11, global = -2.374184112e-13, cumulative = -8.599590607e-11 PIMPLE: iteration 1 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #5 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" Last edited by wyldckat; October 19, 2014 at 06:59. Reason: Reconstructed accidentally deleted post and merged with related post. attached image was lost |
[GAMBIT] Gambit Start Up error .... HELP PLZ! | Abhya | ANSYS Meshing & Geometry | 2 | July 12, 2012 01:40 |
Reading LESModel & Thermophysical Properties In Similar Manner to Function Object | deji | OpenFOAM | 0 | July 27, 2010 11:54 |
plz help its urgent | garima chaudhary | FLUENT | 0 | September 25, 2007 06:28 |
plz help again! | sameera | Main CFD Forum | 9 | August 16, 2007 09:54 |
plz ......help me out.....************************ | krishna | FLUENT | 2 | January 10, 2007 03:53 |
