decomposePar field transfer of particle positions failed
Old   April 29, 2013, 06:35
Post decomposePar field transfer of particle positions failed
sophie_l is on a distinguished road
Hi there,
I am using a lagrangian particle solver based on interFoam. It is ok when running in serial, but when running it in parallel, field transfer error occurs at the stage of 'decomposePar'.
Identified lagrangian data set: "defaultCloud"
Processor 0: field transfer
--> FOAM Warning :
From function Cloud<ParticleType>::initCloud(const bool checkClass)
in file /openfoam/OpenFOAM-1.7.1/src/lagrangian/basic/lnInclude/CloudIO.C at line 124
Cannot read particle positions file
"/OpenFOAM/mparallel/processor0/0/lagrangian/defaultCloud"
assuming the initial cloud contains 0 particles.
The particle position file 'positions' is located in mparallel/0/lagrangian/defaultCloud. In the directory of mparallel/processor0/0/lagrangian/defaultCloud, a 'positions' file is created but it is not decomposed as all the particles are included in it. In other processor subfolders, no '/lagrangian/defaultCloud' is created neither are 'positions' files.
If I rename 'positions' to 'position', there is no problem with parallel running. However, the whole '/lagrangian/defaultCoud/' stuff are ignored and no particles are included from 'decomposePar' onwards.
I checked 'CloudIO.C' file and the code snippets are
template<class ParticleType>
void Foam::Cloud<ParticleType>::initCloud(const bool checkClass)
readCloudUniformProperties();
IOPosition<ParticleType> ioP(*this);
if (ioP.headerOk())
ioP.readData(*this, checkClass);
ioP.close();
if (this->size())
readFields();
else
WarningIn("Cloud<ParticleType>::initCloud(const bool checkClass)")
<< "Cannot read particle positions file " << nl
<< " " << ioP.path() << nl
<< " assuming the initial cloud contains 0 particles." << endl;
So I think ioP.headerOk()) is false, but how can I correct it?
Thank you very much for your help in advance.
Sophie
sophie_l is offline   Reply With Quote
Old   October 28, 2013, 11:53
Dave
triplesfanatic is on a distinguished road
I also have the same problem using Of 1.7.1 (which I have to use). Can anyone help with this please?
Dave
triplesfanatic is offline   Reply With Quote
Old   October 28, 2014, 20:46
Smile
Chen Linya
Chen Linya is on a distinguished road
Hi!
I have the same question of you two. Have you solved the problem?
Looking forward to your reply!
Chen Linya
Chen Linya is offline   Reply With Quote
decomposepar, field transfer, lagrangian particles, parallel
Number of positions in particle tracking sujay CFX 31 November 11, 2020 15:30
solidParticleFoam particle positions caw OpenFOAM Running, Solving & CFD 1 October 6, 2009 03:50
Velocity of Fluid @ different positions of Particle in DPM using UDF pmghadge FLUENT 1 June 16, 2009 19:11
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Number of particle positions in Lagrangian model KK CFX 4 February 16, 2008 04:56
