October 29, 2014, 11:11 |
FATAL ERROR - parallel processing
Rep Power: 11 |
Hi everybody,
I tried to run a case on 16 processors using buoyantPimpleFoam solver. I decomposed the domain according to the user's guide. And then run the case using the command: <path>$ mpirun -np 16 buoyantPimpleFoam -parallel but I got the following error: --> FOAM FATAL ERROR: bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor From function UPstream::init(int& argc, char**& argv) in file UPstream.C at line 79. FOAM aborting I have already used Foam in parallel, and am pretty sure that I've done everything correctly. Anybody has an idea what this error means?! Please help! I may lose my job!! Last edited by P1361; October 30, 2014 at 04:56. |
March 12, 2018, 10:07 |
Rep Power: 8 |
hi, i know it was a long post. Just to share in case others are facing it. I solved it by recheck and changing the number of domains in decomposeParDict to that of the np. I am not sure if your case has the same careless mistake
because line 79 shows this: Code:
if (numprocs <= 1) { FatalErrorInFunction << "bool IPstream::init(int& argc, char**& argv) : " "attempt to run parallel on 1 processor" << Foam::abort(FatalError); } Please correct me if I am wrong. Thanks Last edited by jiahui_93; March 13, 2018 at 04:04. |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected | Djub | OpenFOAM Meshing & Mesh Conversion | 0 | July 15, 2014 04:43 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
