March 29, 2019, 11:05 |
Negative Pressures at water/air Interface?
Rep Power: 10 |
I need help troubleshooting why there would be negative pressure within the water column for an interFoam simulation of water flowing over a weir. See attached image. 1. What would cause the pressure at the interface to be negative? There are ~7 mesh cells between 0Pa and the alpha interface so it isn't negative in just 1 cell (see the line plot in attached image) 2. Is there a way to have the interface correspond to 0Pa? If I change the alpha phase to 0.99 the interface is still negative. |
March 29, 2019, 11:08 |
Boundary Conditions
Rep Power: 10 |
0/U
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet_water { type flowRateInletVelocity; volumetricFlowRate constant 30; value uniform (0 0 0); } outlet_air { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet_water { type pressureInletOutletVelocity; value uniform (0 0 0); } "(inlet_wall|conc)" { type noSlip; } "(wall1|wall2)" { type symmetry; } "(bed1|bed2)" { type noSlip; } top { type pressureInletOutletVelocity; value uniform (0 0 0); } defaultFaces { type empty; Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet_water { type fixedValue; value uniform 1; outlet_air { type inletOutlet; inletValue uniform 0; value uniform 0; } outlet_water { type inletOutlet; inletValue uniform 1; value uniform 1; } "(inlet_wall|conc)" { type zeroGradient; } "(wall1|wall2)" { type symmetry; } "(bed1|bed2)" { type zeroGradient; } top { type inletOutlet; inletValue uniform 0; value uniform 0; } defaultFaces { type empty; } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { inlet_water { type fixedFluxPressure; } outlet_water { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 4286970; value uniform 4286970; } outlet_air { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } "(inlet_wall|conc)" { type fixedFluxPressure; } "(wall1|wall2)" { type symmetry; } "(bed1|bed2)" { type fixedFluxPressure; } top { type totalPressure; p0 uniform 0; } defaultFaces { type empty; } } Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss upwind; //Gauss limitedLinearV 1; div(phi,alpha) Gauss upwind; //Gauss vanLeer; div(phirb,alpha) Gauss interfaceCompression; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,omega) Gauss upwind; div(phi,p_rgh) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; pcorr; alpha.water; } Code:
solvers { "alpha.water.*" { isoFaceTol 1e-6; surfCellTol 1e-6; nAlphaBounds 3; snapTol 1e-12; clip true; nAlphaSubCycles 1; cAlpha 1; // Note: cAlpha is not used by isoAdvector but must // be specified because interfacePropertes object // reads it during construction. } "pcorr.*" { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0; } p_rgh { solver GAMG; smoother DICGaussSeidel; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; tolerance 1e-07; relTol 0; } "(U|k|omega|epsilon).*" { solver PBiCGStab; preconditioner DILU; tolerance 1e-06; relTol 0; } "(U|k|epsilon)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor no; nCorrectors 3; nOuterCorrectors 1; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } relaxationFactors { fields { } equations { ".*" 0.1; } } |
interfoam, pressure, troubleshooting |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Negative pressures in the flow domain | mahut | FLUENT | 2 | September 27, 2007 05:07 |
