pympleDyMFoam turbine with some errors
Old   November 16, 2014, 07:33
Default pympleDyMFoam turbine with some errors
NguyenShuchao
Shuchao is on a distinguished road
I try to run this one, but It has some problems, but I dont know what it is. Im a new person with OpenFoam. So I hope everyone can help me to solve my problem
ERRORS:
PIMPLE: iteration 20
DILUPBiCG: Solving for Ux, Initial residual = 8.78915e-12, Final residual = 8.78915e-12, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 4.41766e-09, Final residual = 4.41766e-09, No Iterations 0
GAMG: Solving for p, Initial residual = 1.95904e-06, Final residual = 9.08207e-08, No Iterations 7
GAMG: Solving for p, Initial residual = 1.55727e-05, Final residual = 1.41936e-07, No Iterations 2
time step continuity errors : sum local = 1.89127e-15, global = -1.08417e-24, cumulative = 9.16512e-23
GAMG: Solving for p, Initial residual = 1.9582e-06, Final residual = 9.08281e-08, No Iterations 7
GAMG: Solving for p, Initial residual = 1.55726e-05, Final residual = 3.41675e-07, No Iterations 1
time step continuity errors : sum local = 4.5514e-15, global = 4.50255e-23, cumulative = 1.36677e-22
DILUPBiCG: Solving for epsilon, Initial residual = 8.72436e-05, Final residual = 1.36558e-08, No Iterations 1
bounding epsilon, min: 0 max: 158.157 average: 1.92211
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 2.64385e-08, No Iterations 4
bounding k, min: 0 max: 1.13733 average: 0.133001
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#6 Foam::incompressible::RASModels::realizableKE::rCm u(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#7 Foam::incompressible::RASModels::realizableKE::cor rect() at ??:?
at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped)
vietkhai@vietkhai-Dell-System-XPS-L502X:~/OpenFOAM/vietkhai-2.3.0/run/turbine3$
Shuchao is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
