discretization error and order of accuracy
Old   November 19, 2014, 07:52
Default discretization error and order of accuracy
Phil_ is on a distinguished road
Hello Foamers,
I'm running a simple steady-state incompressible 2D laminar test-case of a divergent-convergent channel on OF 2.3.0. In order to estimate the discretization error I performed a mesh study with the "Richardson-Extrapolation" (See e.g. "Computational Methods for Fluid Dynamics" by Ferziger and Peric).
The three hex-meshes were refined in x- and y-direction by a factor of r=2.
The numerical schemes are of second order
ddtSchemes
    default         steadyState;
gradSchemes
    default         leastSquares;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
The order of accuracy can also be estimated by:
p = log[(Phi_2h - Phi_4h)/(Phi_h - Phi_2h)] / log r
with index h for the finest mesh, index 4h for the coarsest mesh, and the refinement factor r (here r=2).
For several sample-points along the flow-direction, when using the x-velocity-component, I get orders varying from 1.2 to 3.3. Where do these differences originate from? Are these indicators of local mesh quality and fineness? So if the estimated order is low, the mesh should be refined in this area?
Also for some sample points, the pressure does not increase monotonically, but decreases from the middle to the fine mesh. I'll check the values and samples again, but does anyone have an explanation for that?
In order to estimate the discretization error afterwards, the following equation is used:
epsilon = (Phi_h - Phi_2h)/(r^p - 1)
Best regards
Philip
Phil_ is offline   Reply With Quote
