Can somebody please explain runTimewrite
Like Tree27Likes
  • 16 Post By hjasak
  • 11 Post By MartinB
Old   July 21, 2007, 18:35
Default Dear OpenFoam users Can so
jaswi is on a distinguished road
Dear OpenFoam users
Can somebody explain what does runTime.write() does. I tried to look for the write() member function in Time.H but couldn't find any.
Where can i find the corresponding peace of code !!!!!!
Any help is greatly appreciated
With Best Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   July 22, 2007, 01:53
Default Hi Jaswinder, Did you use d
Martin Karlsson
martin is on a distinguished road
Hi Jaswinder,
Did you use doxygen? Maybe you can find something on:
http://foam.sourceforge.net/doc/Doxy...e-members.html
Regards,
Martin
martin is offline   Reply With Quote
Old   July 22, 2007, 06:00
Default Not too difficult. runTime is
Hrvoje Jasak
Not too difficult. runTime is class type Time:
db/Time/Time.H
which is derived from objectRegistry, which is in turn derived from regIOobject:
db/objectRegistry/objectRegistry.H
db/regIOobject/regIOobject.H
regIOobject has got a fiunction called write() and a virtual function writeObject:
//- Write using given format, version and compression
virtual bool writeObject
IOstream::streamFormat fmt,
IOstream::versionNumber ver,
IOstream::compressionType cmp
) const;
//- Write using setting from DB
virtual bool write() const;
Clearly, write is just a wrapper around writeData. This one is over-ridden for objectRegistry and reads:
bool objectRegistry::writeObject
) const
bool ok = true;
for (const_iterator iter = begin(); iter != end(); ++iter)
if (objectRegistry::debug)
Pout<< "objectRegistry::write() : "
<< "Considering writing object "
<<>name()
<<>writeOpt()
<< endl;
if (iter()->writeOpt() != NO_WRITE)
ok = iter()->writeObject(fmt, ver, cmp) && ok;
return ok;
Thus: loop over all objects registred in the object registry and offer them to write themselves. Each object will decide if it wants to do so, based on the settings, eg. NO_WRITE or AUTO_WRITE.
Clear?
Hrv
Hrvoje Jasak
Old   July 22, 2007, 08:05
Default Thanks Hrv It couldn't be
Thanks Hrv
It couldn't be explained any better :-). Answer from the source itself is ought to be clear.
Thanks
Regards
Jaswinder
Old   January 12, 2008, 13:22
Default hi, i would appreciate it i
Stephan Gerber
stephan is on a distinguished road
hi,
i would appreciate it if somebody could explain how the lagrangian data is writen.
i could not find the place where dieselspray or cloud are included into the "objectRegistry" so that their data is written.
thanks in advance
stephan
stephan is offline   Reply With Quote
Old   June 28, 2010, 03:32
Default write dataFile
Victor Fleischer
Victor is on a distinguished road
Hi at all,
I have a problem with using runTime.write(). I like to write a dataFile only at every writeInterval. The data File contains the position of a flame at every time step. In order to avoid gaps or repetitions in the data-file after a stop in the simulation, the data-file should only be written when the rest of the data is stored to.
I tried it with
if(runTime.write())
myStream<<......
but this does not work right.
Is there anybody how knows what to do?
Thanks a lot in advance,
Victor
Victor is offline   Reply With Quote
Old   June 28, 2010, 04:35
Victor Fleischer
ok, it seems that runTime.write() is the problem! Sorry!
Old   July 28, 2010, 10:04
maximeg is on a distinguished road
Hi all!
I'd like to create files every writeInterval (and which have the name of the corresponding writeInterval). I think I have to use runTime.write() or ofstream, but on this last case, it needs a const char argument (impossible to change/increment the file name).
Anybody have any ideas on how to solve this?
Thanks a lot in advance!
Maxime
maximeg is offline   Reply With Quote
Old   July 28, 2010, 14:24
Martin
MartinB will become famous soon enough
Hi Maxime,
you can use
    if (runTime.outputTime())
#    include "write.H"
to write additional information when a regular time step is written out. Just create a file "write.H" for your solver which handles the output.
When you want to write a volVectorField or volScalarField, the time steps path name is added automatically, so you get your data in different directories, but with the same file name:
    // write pressure in [Bar]:
    volScalarField p
        IOobject
            "p[Bar]", // the file name
            runTime.timeName(), // path to current time step
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        rho_*pd/scalar(100000)
    // explicitly write now:
    p.write();
To create a filename (with time step in filename) for usage with ofstream take this code snippet as an example:
    fileName casePath = cwd();
    Info << "casePath: " << casePath << endl;
    fileName caseName = casePath.name();
    Info << "caseName: " << caseName << endl;
    fileName myFile = caseName
        + "_"
        + runTime.timeName()
        + ".csv";
To use a new filename every write interval and to close your stream just use curly brackets around your code:
        OFstream *myStreamPtr = NULL;
        myStreamPtr = new OFstream(myFile);
        *myStreamPtr << "Valuable information..." << endl;
To handle OFstream in parallel so that only the master writes data:
    if (Pstream::master())
        *myStreamPtr << "Plenty of information" << endl;
... other code, master is collecting data with reduce or Pstream ...
        *myStreamPtr << "Information collected from slaves" << endl;
Martin
MartinB is offline   Reply With Quote
Old   August 2, 2010, 07:33
Robert
rob3rt is on a distinguished road
Hi Martin,
I want to implement a transient boundary conditions, hence I need boundaryData file under constant. However, the problem is the property that I want to vary with time is dimensionedScalar (No_Read in CreateFields.H) instead of volScalarField. What can I do to implement this? What Q value should I put in the constant/transportProperties. I have tried to put this in the solver, but doesn't work.
if (runTime.value() > 500)
Q = 600;
else
Q = 0;
Suggestions will be very much appreciated.
Thanks in advance.
Robert
rob3rt is offline   Reply With Quote
Old   August 3, 2010, 05:53
Default Timw Varying B.C.
  #11
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi Robert
There is some timeVarying... boundary condition in src/finiteVolume/fields/fvPatchFields/derived. May be one of them be useful for you.
Best regards
Good luck
Ata
ata is offline   Reply With Quote
Old   November 27, 2014, 11:42
minoominaii
bgane67 is on a distinguished road
hi
what is writeinterval???
bgane67 is offline   Reply With Quote
Can someone explain the Y plus value jeff bennet Main CFD Forum 32 April 8, 2020 05:58
Can someone please explain this jaswi OpenFOAM 2 July 3, 2007 08:19
Please explain Abby CFX 1 April 25, 2006 06:18
can some one explain this to me? docsri Main CFD Forum 2 December 11, 2002 21:43
someone can explain this..... mazza Phoenics 0 June 4, 2001 11:59
