Calculating center of mass
Old   March 20, 2005, 09:24
Default Does OpenFOAM has the function
Kristaps Ermanis
kristaps is on a distinguished road
Does OpenFOAM has the functionality to calculate the center of mass for a complex geometry? If yes, how to do that? If no, is it possible to implement it, using the libraries of OpenFOAM?
kristaps is offline   Reply With Quote
Old   March 20, 2005, 09:35
Default Try: vector c = sum(mesh.V(
Hrvoje Jasak
Try:
vector c = sum(mesh.V()*mesh.C().internalField())/sum(mesh.V());
You will, of course, need a mesh for your geometry.
Enjoy,
Hrv
Hrvoje Jasak
Old   March 8, 2015, 04:59
Post how to use this code???
Muhammad Usman
13msmemusman is on a distinguished road
can You guide me how to calculate centre of poressure???? can you tell me how to use it as i am new in openfoam vector c = sum(mesh.V()*mesh.C().internalField())/sum(mesh.V());
13msmemusman is offline   Reply With Quote
center of mass for naca airfoil frederic Felten Main CFD Forum 4 November 15, 2016 11:24
How to get the cellcell center to center distance dx dy dz dbxmcf OpenFOAM Running, Solving & CFD 2 August 8, 2008 04:37
Calculating mass flow rate cfd novice Main CFD Forum 7 April 21, 2008 06:38
Calculating mass flow rate cfd novice CFX 2 April 5, 2008 06:26
Calculating mass flow rate cfd novice FLUENT 1 April 3, 2008 18:31
