Home > Forums > OpenFOAM Running, Solving & CFD
chtMultiRegionSimpleFoam 3D
Old   December 9, 2014, 06:32
Default chtMultiRegionSimpleFoam 3D
Wien3 is on a distinguished road
Good Morning!
I have a simple question (at least I guess) that I'm sure you can solve.
I'm using the chtMultiRegionSimpleFoam in order to create a model which consists in a little cube which has heat transfer which my fluid (everything inside a pipe of 5x2x2).
I took planeWall2D as a model, and I achieved to draw it in 2D, but not in 3D model.
The problem is that I don't get a cube of 0.4L, I get a prism of 0.4x0.4x2 (so OpenFoam doesn't take care about Z dimensions). This is my topoSetDict file:
PHP Code:
actions
// fluid
name    fluid;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
box (0 0 0 )(5 0.8 2);  //1°floor
name    fluid;
type    cellSet;
action  add;
source  boxToCell;
sourceInfo
box (0 0.8 0 )(5 1.2 0.8);  //2°floor front
name    fluid;
type    cellSet;
action  add;
source  boxToCell;
sourceInfo
box (0 0.8 0.8)(2.3 1.2 1.2); //2°floor inlet
name    fluid;
type    cellSet;
action  add;
source  boxToCell;
sourceInfo
box (2.7 0.8 0.8 )(5 1.2 1.2); //2°floor outlet
name    fluid;
type    cellSet;
action  add;
source  boxToCell;
sourceInfo
box (0 0.8 1.2 )(5 1.2 2);  //2°floor back
name    fluid;
type    cellSet;
action  add;
source  boxToCell;
sourceInfo
box (0 1.2 0 )(5 2 2);    //3°floor
name    fluid;
type    cellZoneSet;
action  new;
source  setToCellZone;
sourceInfo
set fluid;
// cube
name    cube;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
box (2.3 0.8 0.8 )(2.7 1.2 1.2);
name    cube;
type    cellZoneSet;
action  new;
sourceInfo
set cube;
I also studied the MultiRegionHeaterRadiation and I tried also with this one:
PHP Code:
actions
// cube
name    cube;
type    cellSet;
action  new;
source  boxToCell;
sourceInfo
name    cube;
type    cellZoneSet;
action  new;
sourceInfo
set cube;
// fluid
name    fluid;
type    cellZoneSet;
action  clear;
name    fluid;
type    cellSet;
action  add;
source  cellToCell;
sourceInfo
set cube;
name    fluid;
type    cellSet;
action  invert;
name    fluid;
type    cellZoneSet;
action  new;
sourceInfo
set fluid;
With this one I get the same result (you can see in the image). At first I thought that maybe this solver don't work with 3D, but after studying the second case I'm sure it is not that.
I attach my complete case folder, maybe the failure is there.
Thank you in advance!
File Type: jpg Screenshot from 2014-12-09 11:31:37.jpg (36.5 KB, 15 views)
Wien3 is offline   Reply With Quote
Old   December 11, 2014, 04:17
I solved it!
It was enough to add the front and back face as "symmetry plane", and for having 3D mesh, change z component in the hexaedron in blockMesh (if it is input a "1" error are produced in front and back faces)
I hope it can help somebody!
Old   December 27, 2014, 11:19
Default chtMultiRegionSimpleFoam - sphere around a fluid
salvo-K61IC is on a distinguished road
Hi all guys,
i am trying to simulate a static sphere (hot sphere) in a fluid (cold fluid) which transfers heat by difference of temperature.I created the mesh with salome and i have two regions:
fluidRegion (air) , solidRegion (sphere)
My goal is to get a convergence with HeatFlux (computed by using the tool wallHeatFlux available in OF2.3.X) increasing the cells of the mesh.
I started playing with planeWall2D as a model, but when i started using these kind of problems i do not get any convergence with wall flux.
here i enclose the folder 0 to check BC ( i am not sure about them)! , could someone please help me with this case??
i am trying making different changes but i do not get a right heat flux between both regions, even if residuals go below than 10^-5.
I ll really appreciate, thank you very much in advance!!
P.S. I use OpenFoam 2.3.x and salome 6.6.0 to create meshes
salvo-K61IC is offline   Reply With Quote
Thread Tools
Trackbacks are On
