the tetFinite method in foam-exten3.0 does not support the cyclic BC?
Old   December 15, 2014, 05:11
Default the tetFinite method in foam-exten3.0 does not support the cyclic BC?
ALLEN
allenfieldin is on a distinguished road
why the tetFinite method in foam-exten3.0 does not support the cyclic BC?
I look into the src/tetFiniteElement/tetPolyMesh/tetPolyPatches
but I can not find a cyclicTetPolyPatch....
Does that mean I can not use TetFinite Method for cyclic boundary problems?
I recently tried to build a 3D channel with 2 pair of cyclic boundaries, but it doesn't work after I take into the tetFinite method.
Can anyone give a hint on that? or how can I solve the problem?
Thanks in advance
/Allen
allenfieldin is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 29, 2015 23:42
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
Finite Volume Method in Java with GPU support Don456 Main CFD Forum 0 December 14, 2011 10:43
