December 17, 2014, 08:09 |
SimpleFoam Case not converging
Dominik Allgaier
Rep Power: 11 |
Hello CFDler,
I need your help. For several weeks I try to simulate the following case in OF: Itīs a probe in a box. In the first picture you can see the internal mesh (the upper and right plane of the box are defined as uotlet, the other four one are inlet). Here some facts: - SimpleFoam (basis motorbike tutorial) - SST turbulence model - snappyHexMesh for the probe surface - boundaries: Inlet: U = fixedvalue (39 6 0) p = zerogradient Outlet: U = zerogradient p = fixedvalue 0 Probe: U = fixedvalue (0 0 0) p= zerogradeint The fvsolution, fvscheme und control dicts are set by default. Well, my problem is, that the results physically doesnīt make any sense. So I plotted the residuals (2nd pictures) where you can see, that the case doensīt converge. I think, one reason could be the boundaries at the corner between probe and outlet, as there is a huge velocitiy peak as you can see in the 3rd picture. Maybe the boundaries on the probe and the outlet donīt get along? Or is there something with the Tolerances? Have you got some tips, how I can improve my case? Thanks a lot in advance. Best regards, Dominik |
December 18, 2014, 10:16 |
Dominik Allgaier
Rep Power: 11 |
Here are three more pictures, which may help to understand the problem.
the inflow is 40 m/s and behind the probe the is a peak with 113 m/s, what canīt be. Moreover, the geometrical symmetrie doesnīt reflect in the results. My suspicion is, that the boundaries on the probe surface and the outlet boundaries donīt get along with? Best regards |
December 18, 2014, 12:09 |
Please post the following: 1. checkMesh output (as an attachment or in CODE block) 2. explain what do you mean by "default fvSchemes, fvSolution, and controlDict" 3. IC and BC for turbulent properties |
simpleFoam /water in pipes/ how to obtain and tune the solution? | soonic | OpenFOAM Running, Solving & CFD | 0 | March 29, 2012 10:40 |
How to copy the simpleFoam case to turboFoam | sivakumar | OpenFOAM Pre-Processing | 5 | November 18, 2009 02:49 |
Running a case with simpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 4 | March 28, 2008 07:13 |
SimpleFoam problems with converging maybe skewness | hoochie | OpenFOAM Running, Solving & CFD | 4 | May 14, 2007 07:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
