December 17, 2014, 08:31 |
icoFoam not giving proper velocity
Rep Power: 12 |
hello Foamers;
I was trying to replicate OpenFoam tutorial case of cavity by creating geometry in freecad and mesh in salome instead of using blockMeshDict to see if could achieve same result i got similar pressure variation as that of blockMeshDict but different velocity results are not same could you guys please see what is the error in my case setup that i have attached below Any help would be appreciated |
December 18, 2014, 06:23 |
Rep Power: 12 |
Problem solved .Wrong dimensions input by mistake
LES and TKE calculations | MST | Main CFD Forum | 3 | May 30, 2016 06:26 |
Radial velocity and tangential velocity on centrifugal fan, | johnnyp | FLUENT | 2 | May 24, 2013 07:10 |
problems with velocity and pressure boundary conditions inb IcoFoam | m5m5kh | OpenFOAM Pre-Processing | 3 | April 3, 2013 00:55 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 08:42 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
