pisoFoam - Too high Courant Numbers
Old   December 30, 2014, 08:47
Default pisoFoam - Too high Courant Numbers
Harak is on a distinguished road
I want to simulate a 3d case where a flow in a channel with a square cross section passes a barrier. See the sketch below.
It's my very first case after going through the tutorials
So, I decided to use pisoFoam since I believe it's well suitable for my case.
My problem is that I get incredible high Courant numbers so that my calculation crashes.
I've put some info for you. I hope you guys can help me
fvSolution:
https://dl.dropboxusercontent.com/u/59780963/fvSolution
fvSchemes:
https://dl.dropboxusercontent.com/u/59780963/fvSchemes
checkMesh:
https://dl.dropboxusercontent.com/u/59780963/checkMesh
And that's the error I get:
Time = 0.025
Courant Number mean: 3.03546e+85 max: 1.06297e+89
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.44087e-15, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8 Foam::fvMatrix<double>::solve() at ??:?
at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
at ??:?
Floating point exception (core dumped)
Harak is offline   Reply With Quote
Old   December 30, 2014, 12:32
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hey,
The easiest option is to use pimpleFoam where you can set the maximum courant number.
If you want use pisoFoam, you need to reduce the time step (delta t) in order to reduce the courant number.
Kind Regards,
Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius
Alhasan is offline   Reply With Quote
core dumped, floating point error, floating point exception, pisofoam
Visualizing mesh regions with high courant number? Endel OpenFOAM 2 August 20, 2013 03:57
Does MULES::implicitsolve allow for Courant numbers > 1? Philip OpenFOAM 4 May 31, 2011 06:25
Very high courant number, time step continuity errors and bounding epsilon erncyc OpenFOAM Running, Solving & CFD 1 March 24, 2011 11:00
Energy balance error with high prandtl numbers. David_010 OpenFOAM Running, Solving & CFD 0 January 20, 2011 05:21
high and low reynolds numbers - what does it mean Bo Busk Jensen Main CFD Forum 3 September 5, 2002 05:41
