libz.so.1: no version information available
Dear Foamers,
I'm trying to run a Steady-state simulation using the rhoSimpleFoam solver and the k-omegaSST RASmodel. In order to do this I have copied a tutorial folder of rhoSimpleFoam adding the new mesh. However, I get the following errors, after 2 or 3 timesteps: Code:
#0 Foam::error::printStack(Foam::Ostream&)addr2line: /lib64/libz.so.1: no version information available (required by addr2line) I'm using OpenFoam 2.3.0 on Centos 6.6 and this errors occurs also using other solvers and models. Thanks in advance, Dmaz |
Greetings Dmaz,
A few questions:
Bruno |
Hi wyldckat,
thanks you for replying. I followed the instructions of this link: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.5 I have checked, the version of Centos: is 6.2. I havent found the instructions for that version. OF seems to work correctly but when a simulation crash it shows that error. I'm verifing the tutorials with OF installed in two system, Ubuntu 14.04 and Centos 6.2. The simulations crash about at the same iteration, but in Centos the errors refer also to libz.so. Is it possible that this error doesn't affect the simulation? Dmaz |
Hi Dmaz,
The problem shouldn't affect OpenFOAM's binaries. The message indicates that the problem is related to a binary that OpenFOAM is using to assist in handling the print stack operation, namely addr2line: Code:
addr2line: /lib64/libz.so.1: no version information available (required by addr2line) Code:
which addr2line Code:
$ which addr2line Beyond this, it seems as the "libz.so.1" version your addr2line is getting isn't the same version of "libz.so" that was used to build addr2line. If this is the case, then you should try to remember if you had any other shell environment paths loaded up that could have interfered with the build process. Best regards, Bruno |
