Change MotorBike Tutorial to Water
Old   January 7, 2015, 20:57
Default Change MotorBike Tutorial to Water
Connor Anderson
connoranderson is on a distinguished road
Hi All,
This is my first post on this forum, so thanks in advance for your help!
I'm working on a project where I'm designing some hydrofoils that will be traveling underwater under a sailboat. I'm trying to perform an analysis of the lift/drag characteristics of various models of foils.
For starters, I tried using the already existing motorBike tutorial, but replacing the geometry with my own, updating the initial conditions for a new velocity, updating transportProperties to change Nu, and lastly updating blockMesh to accommodate the size of my foil. However, when I run the program, it meshes beautifully, but freezes once it gets to the iteration 20 (or whatever value I set the writeInterval constant to in controlDict). When I change the fluid properties back to air, the solver can finish running, but modifying Nu seems to prevent the solver from finishing the case.
My question to the OpenFOAM community is this, how would you go about updating the motorBike tutorial for water? I believe that I lack the openFOAM knowledge to make my current case work, so I would love to start from scratch and hear someone's step-by-step analysis of what would need to change in the control files.
Thank you!
connoranderson is offline   Reply With Quote
foil, hydrodynamics, hydrofoil, openfoam, water
I need UDF file and tutorial for pool boiling of water omid_h Fluent UDF and Scheme Programming 1 July 24, 2013 09:45
Boiling water tutorial ņapi FLUENT 0 April 18, 2013 15:16
motorBike Tutorial: Cannot plot U and solution seems not to converge Jaggy_Snake OpenFOAM Running, Solving & CFD 2 December 11, 2012 06:27
Motorbike Tutorial ChrisPro OpenFOAM 4 June 8, 2011 09:29
InletOutlet boundary condition in motorBike tutorial madad2005 OpenFOAM 2 November 27, 2009 08:15
