Droplet evaporation?
Old   January 18, 2015, 11:37
Default Droplet evaporation?
sayed
sayed is on a distinguished road
Dear all,
I want to simulate droplet evaporation on a hot surface with temperature dependable surface tension coefficient . I have also to change the vapour pressure in the surrounding air to the droplet in every case to evaluate it's effect. The droplet resting on a heated surface (it's temperature ranges between 30 to 60 C). Please, any one here have any idea if there is a solver to solve my cases in OpenFOAM and which one.
As you can see my problem is very complex and comprises all aspects of CFD:
1) Multiphase flow with heat transfer and temperature dependable surface tension.
2) Phase change from water to vapour.
3) Mass transfer between air and vapour.
4) Evaporative cooling of the liquid-gas interface due to the released latent heat of evaporation.
5) Vapour partial pressure effect on the evaporation process.
Thank you and best regards,
Sayed
sayed is offline   Reply With Quote
Old   January 18, 2015, 11:51
Nima Samkhaniani
nimasam is on a distinguished road
Dear
There is no solver for this simulation, and you should code it yourself,
I suggest that read and simulate with compressibleInterFoam and interPhaseChangeFoam
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 20, 2015, 02:56
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
I think the thesis of Kunkelmann http://tuprints.ulb.tu-darmstadt.de/...Kunkelmann.pdf on boiling droplet is a very good reference for you. I believe that he used interDyFoam to simulate the process.
Duong
duongquaphim is offline   Reply With Quote
Old   October 23, 2018, 03:10
rasoul
rasool_soofi is on a distinguished road
Hi
you can use interThermalPhaseChangeFoam solver.
rasool_soofi is offline   Reply With Quote
2D VOF Droplet evaporation model. Multi-component problem nb92 Fluent Multiphase 0 February 28, 2014 10:36
Droplet evaporation in fluidised bed. Help with the model? nb92 FLUENT 0 February 27, 2014 04:17
DPM Modelling: Colloid droplet evaporation Meng Wai Woo FLUENT 1 August 1, 2007 00:27
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
can CFX5 or 10 do this (about droplet evaporation) steven CFX 0 February 19, 2006 17:02
