Svensen |
January 29, 2015 10:26 |
Transient boundary conditions
5 Attachment(s)
I try to repeat the native experiment using OpenFOAM 2.3.0. Solver pimpleFoam is used. The domain has a complex form with one inlet and one outlet. For boundary conditions it was setted values of velocity at inlet and pressure at outlet. The flow is laminar, fluid is newtonian.
According to experimental data the velocity at inlet and pressure at outlet are trancient.
In the simple case, when I fixed the values for them (using fixedValue), I've got a good results (files "statics_*.png).
But when I tried to make the trancient boundary conditions, at the inlet there are oscillations for pressure, which doesn't correlate with experimental data (files "trancient_*.png").
I think that error is in the boundary condition for P at the inlet. It seems to me that "zeroGradient" have to be replaced by something else, but I don't know what type fo BC I need to use for this BC at inlet. Could someone help me ??
BC for velocity:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type uniformFixedValue;
uniformValue tableFile;
tableFileCoeffs
fileName "$FOAM_CASE/bc/inlet_velocity.bc"
outOfBounds repeat;
outlet
type zeroGradient;
vessel
type fixedValue;
value uniform (0 0 0);
BC for pressure:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 9.421284545;
boundaryField
inlet
type zeroGradient;
outlet
tableFileCoeffs
fileName "$FOAM_CASE/bc/outlet_pressure.bc"
outOfBounds repeat;
vessel
type zeroGradient;
file controlDict:
application pimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 2;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.1;
purgeWrite 0;
writeFormat binary;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 1;
maxAlphaCo 1;
maxDeltaT 0.1;
file fvSolution:
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.01;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pFinal
solver GAMG;
tolerance 1e-06;
relTol 0;
mergeLevels 1;
"(U|k|epsilon)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-05;
relTol 0.1;
"(U|k|epsilon)Final"
$U;
tolerance 1e-05;
relTol 0;
PIMPLE
nOuterCorrectors 2;
nCorrectors 4;
nNonOrthogonalCorrectors 5;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
equations
"U.*" 1;
"k.*" 1;
"epsilon.*" 1;
