Selecting proper turbulence model for oscillating heave column |
February 2, 2015, 08:07 |
Yuanchuan Liu
Rep Power: 13 |
Hi everyone,
I am working on an oscillating heave column case where free surface is involved as you can see in the attached first image. Basically the column oscillates in the heave (Z) direction. I use the oscillatingLinearMotion in the solidBodyMotionFvMesh library to simulate the movement so that overall mesh quality is preserved. My problem is that for such a case since no current is considered, it is quite difficult to estimate a proper yPlus value for meshing and also to select an appropriate turbulence model. Due to the vortex generated near the corners, velocity variance is quite large (second image) resulting in a varying yPlus value from well below 1 to almost 100 (third image). I currently use k-omega SST model with wall functions but I am not sure if it is all right. Does someone happen to have some experience on a similar topic? Any help will be appreciated. Thank you very much! Best wishes, Yuanchuan |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 03:41 |
Help Selecting Turbulence Model for VOF Problem | NavierIsStoked | FLUENT | 0 | November 1, 2013 11:27 |
Compressible turbulence model issues | 351Cleveland | OpenFOAM | 5 | October 24, 2013 15:41 |
About selecting Turbulence model in VOF model | mariam.sara | FLUENT | 8 | April 29, 2012 16:23 |
