nsreddysrsit |
February 6, 2015 19:15 |
"libsimpleFunctionObjects.so: cannot open shared object file"
After running icofoam i am getting the following error,
anybody please what is the reason
/OpenFOAM/shreenica-2.3.1/run/tutorials/incompressible/icoFoam/vortex_shedding/c1$ icoFoam
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.1-bcfaaa7b8660
Exec : icoFoam
Date : Feb 07 2015
Time : 05:41:58
Host : "shreenica-SVF14212SNB"
PID : 2878
Case : /home/shreenica/OpenFOAM/shreenica-2.3.1/run/tutorials/incompressible/icoFoam/vortex_shedding/c1
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable::open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libgroovyBC.so"
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
--> FOAM Warning :
dlopen error : libsimpleFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libsimpleFunctionObjects.so"
--> FOAM Warning :
From function dlLibraryTable::open(const dictionary&, const word&, const TablePtr&)
in file lnInclude/dlLibraryTableTemplates.C at line 67
Could not open library "libsimpleFunctionObjects.so"
--> FOAM FATAL ERROR:
Unknown function type patchMassFlow
Valid functions are :
4
patchProbes
probes
sets
surfaces
From function functionObject::New(const word& name, const Time&, const dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 92.
FOAM exiting
